It is currently Thu Aug 13, 2026 11:13 am
How Many "Blow-thrus" before the engine stops running?
Poll ended at Fri Apr 13, 2007 7:13 pm
1 head gasket blow-thru 17%  17%  [ 2 ]
2 head gasket blow-thrus 17%  17%  [ 2 ]
3 or more head gasket blow-thrus 67%  67%  [ 8 ]
Total votes: 12
PostPosted: Sat Apr 07, 2007 7:13 pm
I pulled the head off the 66 Dart wagon, sure enough, it has a blown head gasket... big time.
Slant Six engines continue to amaze me... I can't believe we were able to drive this car 400+ miles home, towing another car! :shock: :roll:
PostPosted: Sat Apr 07, 2007 7:55 pm
Wow! This has got to rival the 198 on salad oil for a "can't kill it" durability story!
PostPosted: Sat Apr 07, 2007 8:10 pm
Looks like it had 3 cylinders down, or were the other 2 torn on tear down?
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Apr 07, 2007 8:22 pm
The gasket's fire rings were burned thru on 4 different cylinders. :oops: :cry:
The good news is that all the piston tops look fine so everything should go back together with-out much trouble.
PostPosted: Sat Apr 07, 2007 8:36 pm
Damn!
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Apr 08, 2007 12:00 am
Looks like a poster child for "mill your head and block when rebuilding, don't skip that step".
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
 Post subject: Head Gasket
PostPosted: Sun Apr 08, 2007 5:23 am
I believe you got your money's worth from that part....
Amazing!
PostPosted: Sun Apr 08, 2007 6:13 am
This I've got to hear.
I'm amazed at that shot of the head gasket. When I blew one I didn't have anywhere near that sort of damage - then again, the only sign it was blown was that my coolant was going away and I had big clouds of steam out the exhaust, no loss of power or anything.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sun Apr 08, 2007 6:45 am
Is this the stroker motor?
PostPosted: Sun Apr 08, 2007 7:19 pm
looks just broke in to me.
PostPosted: Sun Apr 08, 2007 7:31 pm
Yes, this is the 260 stroker engine I built about 10 years ago.
I was glad to see that the pistons and cylinder walls were all in good shape.
The plan is to surface the head, deck the block and stick in a new set of rings and bearings.
PostPosted: Mon Apr 09, 2007 10:28 am
I would say that operating conditions may have exceeded the designed operational envelope of that particular gasket.
Holy carp. Any idea what triggered the failure?
PostPosted: Mon Apr 09, 2007 4:38 pm
It couldn't possibly have been the full throttle sprints down the track nor the hundreds of miles towing a trailer with another car on it. LOL
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Apr 09, 2007 5:30 pm
You have to see this car to believe what it does.
In the hotly contested modified/pro/beater class the wagon really hauls in a lot of extra points for pulling a race car all the way there and back as well as competing. It really puts the trailer queen thing into perspective.
Add to that 2 guys that are not afraid to break stuff.....
Add Las Vegas is in a desert on the other side of the Cordillera...
How would you like to be that 904?
PostPosted: Mon Apr 09, 2007 5:51 pm
Torqueflites are tough. All they ask is to be kept reasonably cool and an oil change and band adjustment every couple of year and they're usually happy with that. I'd stack that 904 against just about anything except a 727.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
