It is currently Tue Dec 23, 2025 3:22 pm
 Post subject: Cranking but no fire !
PostPosted: Sat Apr 14, 2007 5:14 pm
Hi Everyone -
Have put the Dart back together after the paint job and have been driving it over the last month. My car / build is referenced here: http://www.slantsix.org/forum/viewtopic.php?t=8938
It has been running great...up till today !! Went to start it up and all it does is crank and not fire. I have checked the ballast resistor, coil, harness connection between distributor and control module (orange box) and all have 11-12 volts at positive side. I inspected the distributor. The rotor and cap look good. I took off the coil wire at the distributor and held it to the block while cranking the engine - no visible spark !! Is this my weak link ? Is the coil (newer Accel) bad ? Could the control module be causing this non-fire condition ?
Fyi - I installed new magnecor wires and NGK plugs per Dan's recommendation and the Dart was running great up till today !! :)
Please give me your thoughts and additional leads / ideas to track down.
Thanks
66Dart
PostPosted: Sat Apr 14, 2007 5:23 pm
H'mm. Bad orange box comes to mind! You can quickly test the coil by disconnecting the two primary wires from it, running a wire from +12v to the coil (+) terminal and, while holding the coil's spark cable about 1/4" away from the cylinder head, alternately making and breaking the connection between the coil (-) terminal and ground via another test wire. If you get a spark, replace the orange box, perhaps with the HEI upgrade, installing at the same time a NAPA Echlin long-tip rotor # MO-3000 and Standard-Bluestreak CH-410X cap.
PostPosted: Sat Apr 14, 2007 6:00 pm
Thanks for the test idea on the coil. I'll perform that test tomorrow morning and let you know what happens. If I end up replacing the coil, I'll try the MSD-2 (8202) blaster this time in place of the Accel.
Yes, I have already placed an order with NAPA for the Echlin rotor and will pick it up on Monday. I need to order the Std/Blstrk cap from another parts store this week. I'll put those on when I gather the parts. The existing rotor and cap are the MP electronic distributor package I purchased 5 years ago. They only have approx. 6K miles on them.
I am impressed with the Magnecor wire set (8.5mm) I ordered. They were cut to the proper lengths. All I had to do was transfer over the 'boots' and they look great !
Too early to tell / report on the NGK's performance at this time :)
Thanks Dan
PostPosted: Sun Apr 15, 2007 4:54 pm
Performed the coil test per Dan's recommendation. Yes, there is a spark. Looks like I'll be purchasing a new orange box this week.
Thanks for the assistance Dan.
PostPosted: Sun Apr 15, 2007 5:37 pm
I wouldn't. See here.
If you're keeping the Mopar type box rather than switching to HEI, you can do much better with a Standard-Bluestreak or NAPA Echlin box than with the junk Mopar are selling now.
Users browsing this forum: Google [Bot] and 12 guests
