It is currently Thu Dec 25, 2025 3:44 am
PostPosted: Mon Apr 16, 2007 1:24 pm
MP P4120492 Umbrella Style Viton Valve Seals were mentioned in several of the 246 search results dating back to 2001.
Teflon were noted to require guides to be machined.
For a daily driver, stock compression & intake/exhaust, are the Viton seals still best bet & adequate for my 65 225:?:
1965 Dart 110k, 225, Carter BBD Super Six, 2 1/4 single exh., sbp manual scarebird front disc, 7 1/4 rear 2.94 sure grip, 14 x 4.5 OEM wheels, 833 OD with hyd. throwout bearing, HEI, electric fan, ram air/heated air, Accusump. http://plymouthcarclub.com/
PostPosted: Mon Apr 16, 2007 1:41 pm
thats what I plan to use on my car with mild head work 2bbl and a 4 speed I will be putting the engine together soon ill let you know how they work (also they look different then in the pic their is a short and a long seal the short goes on the exh. valve)
PostPosted: Mon Apr 16, 2007 2:14 pm
You needn't pay MP markup for valve stem seals...
PostPosted: Tue Apr 17, 2007 6:11 am
they only list for $16.00
PostPosted: Tue Apr 17, 2007 6:18 am
http://www.wholesalemopar.com/parts.htm
$15
Users browsing this forum: Ahrefs [Bot] and 6 guests
