It is currently Wed May 27, 2026 9:55 pm
PostPosted: Mon Apr 16, 2007 9:29 pm
If I get time tomorrow I'm going to do a compression check on my engine, and I was wondering where you guys recommend connecting the start switch? I would expect just the pattery pos. and the connection that the stock starter switch connects to on the starter relay. Is this the best way to go?
I second guess myself alot....for good reason.
PostPosted: Mon Apr 16, 2007 9:57 pm
I hook my button up to the positive terminal on the relay itself, and to the starter terminal also on the relay. :D
PostPosted: Mon Apr 16, 2007 10:51 pm
Oh sure, do it the easy way...
Note to self: look closer at the relay next time...
PostPosted: Tue Apr 17, 2007 12:43 am
I usually go to the relay coil as well. Either that, or if I don't feel like looking for my starter switch, a big screwdriver shorting out the two big relay posts work.
Come to think of it last time I did it I just kept walking back and forth between the plugs and cab using the column key.
