It is currently Mon Oct 12, 2026 9:04 am
 Post subject: Dizzy gear
PostPosted: Tue Apr 24, 2007 12:56 am
Hey all
I tried staring my 68 Valiant the other day only to find it backfiring and coughing. I went through everything I could think of till I found that the distributor gear was missing teeth.
Ive replaced the gear but I need to where the rotor button is supposed to be in relation to the stroke?
Any help would be much appreciated :D
PostPosted: Tue Apr 24, 2007 6:46 am
The rotor should point to about the 4:00 position when the frontmost cylinder is at the top (TDC) of its compression stroke.
 Post subject: wondering same thing
PostPosted: Tue Apr 24, 2007 8:12 am
Somewhere I heard that the rotor is supposed to 'point at' the #1 cylinder at TDC. Is that for V-8's? It sounds like with the /6 you want the rotor to 'point away' from #6 cylinder?
 Post subject: Re: wondering same thing
PostPosted: Tue Apr 24, 2007 8:16 am
Nope.
You want the rotor to point to about 4:00 clock position as you look down at the distributor while you're standing at the RH fender of the vehicle.
PostPosted: Tue Apr 24, 2007 8:25 am
The "rotor points to #1" is for small block Mopar V8s.
For the SL6, pointed to the 4:00 position as SSDan noted.
 Post subject: 4 O'clock: Clear
PostPosted: Tue Apr 24, 2007 8:30 am
Thanks, you guys are the most.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Tue Apr 24, 2007 5:17 pm
Thanks all
PostPosted: Tue Apr 24, 2007 5:24 pm
It depends on how the cap was wired and how the distributor was installed last time. If you point it at 4:00 and the #1 wire is at 12:00, you got prolems. :shock:
PostPosted: Tue Apr 24, 2007 5:38 pm
Amen
Users browsing this forum: Bing [Bot] and 26 guests
