It is currently Wed Dec 24, 2025 12:49 pm
 Post subject: in deep
PostPosted: Mon Apr 30, 2007 4:54 pm
I'm attempting to follow the protocol found at the Jim's Performanced Automotive site, as recommended here. That is the intake centerline method. I started by aligning the dots on the comp timing chain. The point of max lift on cylinder #1 seems to be @ 229 degrees. The cam centerline is supposed to be 105 deg (St-1 carb. Are the dots 124 degrees off, or am I? The duration is 226 @.50. The cam card is, of course, lost in a singularity vortex. Any help?
PostPosted: Mon Apr 30, 2007 5:37 pm
You could try an entanglement trace to find out where it went.
The Old Goat '83 D150 225-2
AKA Ice Titan
 Post subject: Uhhhhhh
PostPosted: Mon Apr 30, 2007 8:49 pm
Beyond the event horizon? D'oh: I just figured out that I was on the exhaust valve rather than the intake. THAT might have something to do with my result. :oops:
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
 Post subject: good call oldgoat83
PostPosted: Mon Apr 30, 2007 9:08 pm
If we let the location of the cam card equal A and the location of the hapless cam installer equal B then the relationship of A to B, in classical terms would most likely be expressed by H(A:B)=H(A)+H(B)- H(A,B) neglecting quantum effects. Or I might have recycled it with the box the cam came in. :?
PostPosted: Mon Apr 30, 2007 9:22 pm
Just split the overlap event over TDCEx and call it done. :P :wink:
PostPosted: Mon Apr 30, 2007 9:29 pm
Haha...... Doc and his "voodoo" ways.
Excuse me, does this smell like chloroform to you?
Users browsing this forum: Google [Bot] and 13 guests
