It is currently Sat May 23, 2026 1:43 am
 Post subject: 65 AC questions
PostPosted: Tue May 01, 2007 10:11 pm
Ok...got a AC setup off a 64 valiant w/ slant six..will the same brackets work on my 65 w/ a 318 v8?..Im guessing they have brackets for the 273 that would work
Also, anyone have any info on the A.R.A. brand AC units from back then?
Couldnt find any info online..thanks!
PostPosted: Wed May 02, 2007 1:10 am
http://cgi.ebay.com/ebaymotors/A-R-A-ac ... dZViewItem
Looks kinda like this, yet there are a bunch of wires...im guessing ground and power....hmm
PostPosted: Wed May 02, 2007 4:21 am
The slant six brackets are different then the 273/318 brackets. You can get brackets for your engine at a junk yard, or there are companies that make new "mount and drive" kits. You will need to decide wheather you want to look original, under the hood, and use the large RV-2 compressor, or the better, smaller, Chrysler/Sanden compressor.
I have the wire color coding of the ARA unit out in the shop. I will post it later
PostPosted: Thu May 03, 2007 2:13 pm
The compressor is a sankyo unit.
Users browsing this forum: Ahrefs [Bot] and 6 guests
