It is currently Sun Dec 28, 2025 2:02 am
Post new topic  Reply to topic  [ 442 posts ]  Go to page Previous 1 2 3 4 530 Next
PostPosted: Sun May 06, 2007 10:33 am
The stand off tubes are to make the oil puddle around the lifters. The lifter bores where groved to direct oil down on to the cam.
Ingition band is the MSD6AL with Blaster 2 coil.
Cooling is a BeCool AL rad with dual 11" Spal fans (pullers) and a Spal controller. Alternator and wiring has been up graded to a modern 100 amp out of an Intrepid.
Last edited by Bren67Cuda904 on Mon May 28, 2007 10:50 am, edited 1 time in total.
PostPosted: Sun May 06, 2007 1:58 pm
Thanks for sharing!!
Bill Jacobs
PostPosted: Mon May 07, 2007 6:04 pm
More Pics
Intake/Exhaust and 470CFM Holley Truck Avenger carb.
http://www.renaissanceracing.com/Albums ... eaner.html
http://www.renaissanceracing.com/Albums ... MCarb.html
Belt size from damper to water pump is Duralast 13345 (1cm x 87,5cm)
PostPosted: Tue May 08, 2007 4:24 pm
ARRRRG. Very frustrating. Dyno testing is being pushed back again. The good news is the motor is done. The bad news is that the shop where we plan to test the motor was broken into and about $60,000 worth of engines, and tools where stolen. The good news is that the dyno wasn't messed with. The bad news is it has set them back about 4-5 days.
PostPosted: Tue May 08, 2007 6:39 pm
Brennan, Everything about this post is cool! Thanks for sharing. . What are the stand off tubes for in the lifter valley? I am eager to see how this baby runs, and what kind of power you get.
Sam
One thing that was doen on my head was where the oil returns. The guy that ported the head ground and smoothed it where the oil returns. I did that on a set of SB heads I am working on.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Sun May 20, 2007 6:48 pm
Well tomorrows what I like to call "Dyno Day". :!: :!:
Wish me luck. :D
SlantSixDan wrote:
Will you have an oscilloscope hooked up so you can keep track of secondary ignition voltage? That would add tremendously to what can be learnt from the data you're collecting.
Not sure if they have one.
 Post subject: The results are in
PostPosted: Mon May 21, 2007 6:43 pm
PostPosted: Mon May 21, 2007 7:31 pm
Dyno predictions:
I asked for more HP and torque than a stock 440.
He smiled a few days ago and sayed with a grin "nooo problem"
While I feel that this was an unrealistic goal for a Slant, your motor guy missed it a ton. I think 275 was realistic, and they didn't get close to that either.
Unless they really screwed the head up porting it you have major tuning issues that will net you a bunch more power I believe.
At least all the pieces stayed inside. :D
In case you are wondering, my good motor makes roughly 250ish off the hose.
PostPosted: Mon May 21, 2007 7:56 pm
What CR are you running on that motor? Is that a race fuel only motor?
When I get the motor in the car I am heading to the chassis dyno.
PostPosted: Mon May 21, 2007 8:26 pm
I am just under 11-1. Without the hose it runs best on 93 pump gas.
Just remember that a chassis dyno will give 18-20% lower numbers than an engine dyno.
PostPosted: Mon May 21, 2007 8:36 pm
18% - 20%? I was thinking it would be about 25%. What are your (anyone) thoughts on some of the other issues?
Blowing out the tape.
Contamination of the air.
“This dyno’s results are not inflated"
They seemed delighted with the 300.9 ftlbs. Is this a really good number?
PostPosted: Tue May 22, 2007 4:04 pm
humm, I surprized that I am not getting much responce here. :? Is it that this thread is lost in the heap or does no one have any comments on some of my consurns?
PostPosted: Tue May 22, 2007 4:51 pm
Patience my friend. The thread is only a few hours old. There will be responses when people get settled in to read later on this even. Remember it's not even 5:00 yet on the west coast.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue May 22, 2007 5:29 pm
Here are a few dumb questions that I have:
1. Is the cam off? (Really dumb, but possible, did the cam eat a lobe?)
2. What was the vacuum at idle and at WOT?
3. Any readings on A/F ratio from a wide band O2 sensor?
4. Can the dyno guy show you how/when his dyno was calibrated?
5. What was the oil level? Could the engine have been overfilled significantly?
I am trying to think of obscure or obvious issue that could give you the results that you got. I loved the video. Your engine sounds great.
PostPosted: Tue May 22, 2007 6:01 pm
I'm thinking ... this are good suggestions, but I'm stumped. I would have expected like 270 horses at least. CR was? ?
Juan Ignacio Caino
