It is currently Thu May 21, 2026 1:07 pm
 Post subject: Flooding
PostPosted: Tue Aug 07, 2007 7:22 am
61 valiant with 170 slant 6. New single barrel carb., new fuel pump. Every time I start the car hot the engine is flooded. Starts fine when cold. Thought it couls be from pressure in the tank, put in a vent but the problem still exists. Any ideas?
PostPosted: Tue Aug 07, 2007 7:54 am
Do the fuel line mod on the main page.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Aug 07, 2007 8:22 am
Make sure the manifold heat control valve in the exhaust manifold isn't stuck. Make sure the carburetor gasket is the 3/8" thick one, not the 1/8" thin one. Do the Fuel line mod. And, tell us more about the carburetor you installed: Is it really new, or is it a "remanufactured" unit from the parts store?
PostPosted: Sat Aug 11, 2007 12:12 pm
Changed gasket under carb to thick one, did fuel line modification. Warmed the car up and restarted it a couple of times. I think the problem is fixed. I will take the car out on Monday to confirm. I appreciate the info from people more knowledgeable then myself. As I am a newby here I will probably have more questions in the future. Thanks again.
Blake
Users browsing this forum: bcschief and 20 guests
