It is currently Sun May 17, 2026 9:39 pm
 Post subject: Slant 6 Not Starting
PostPosted: Fri Aug 10, 2007 3:15 pm
In my 63 Dart, the motor will not start. It has a new distributer, the points are set right, it is on the right tooth, it has spark. But it will just crank and crank, it wont even try to start. There is plenty of fuel pressure to the carb, but from the carb, there is just a dribble of gas when I give it gas. I dumped some fuel down the carburetor, but it still does the same thing. Could it be the timing, or what?
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Fri Aug 10, 2007 4:58 pm
need mo info. When was the last time it ran.? Have you checked the valves and valve lash? Is the distributer 180 degrees out. Have you tried static timing it?
PostPosted: Fri Aug 10, 2007 7:27 pm
I got it worked out. Thanks though.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Fri Aug 10, 2007 8:45 pm
Well, what was it?
Excuse me, does this smell like chloroform to you?
PostPosted: Fri Aug 10, 2007 9:31 pm
do tell? we are all curious.
Rod :? :D
PostPosted: Fri Aug 10, 2007 10:14 pm
i messed with the timing a little. it sounds kind of lame, but when I made the first post, I was a little upset.
1970 Nova 12.53@108
1970 Bug 15.38@87
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
