It is currently Mon Nov 17, 2025 11:09 pm
 Post subject: Exhaust flange gaskets
PostPosted: Sun Aug 19, 2007 9:16 pm
I heard a while ago that some company makes exhaust flange gaskets (and manifold gaskets for GM engines) that will expand when subjected to exhaust heat and will form a perfect seal. Anyone else heard of these? The gaskets I use on the downpipe flange in my Duster (and where I bolted in straight pipes in place of my truck's catalytic converters) never want to seal and leak pretty heavily after no more than a couple weeks.
PostPosted: Sun Aug 19, 2007 10:08 pm
I know there's reusable copper and aluminum header collector seals........
Don't know about ones for normal manifolds.
PostPosted: Mon Aug 20, 2007 6:55 am
I'm not worried about the manifold gaskets (that was just what was being talked about when they came up). All I need is a bunch of 2-bolt flange gaskets. And NO ring gaskets!
PostPosted: Mon Aug 20, 2007 11:13 am
Would this work?
http://store.summitracing.com/partdetai ... toview=sku
PostPosted: Mon Aug 20, 2007 5:33 pm
Boy that'd be about perfect if it was about 1/8" thick....
PostPosted: Mon Aug 20, 2007 6:11 pm
I still think you've got a warped flange.
PostPosted: Tue Aug 21, 2007 6:53 am
I think so too, but I don't want to spend the money on having a new exhaust system done up until I make up my mind on if I'm going to keep the stock exhaust manifold, go with a set of Dutra Duals, or wait and see if this new header project pans out...
PostPosted: Tue Aug 21, 2007 1:19 pm
I wouldn't think it would be too much elbow grease involved in resurfacing it by hand. Is the manifold still on the engine?
The Old Goat '83 D150 225-2
AKA Ice Titan
