It is currently Fri May 08, 2026 5:39 pm
PostPosted: Sun Aug 26, 2007 5:10 pm
What would cause the EI box to get so hot that it melts the insulating gel inside the back of the box where it mounts to the firewall? I have 6.75 volts at the + end of the coil, ballast resister is good. Truck runs, but this is the second module that has had this problem. The first was the original.
Mike
Good gun control is hitting your target repeatedly
PostPosted: Sun Aug 26, 2007 6:16 pm
Four-pin module or five-pin module? What brand of module are you using?
PostPosted: Sun Aug 26, 2007 6:28 pm
I know this happened to my Duster before I bought the car. It was pretty apparent by the mess on the inner fender. I never had any problem with that myself, but I did buy the car in Florida, could have just been the heat down there. I lived there for a year and never had the problem while I owned it, and have never had the problem in the 9 years I had the car here in Chicago.
Could have been the outside temps, could be an internal problem. If the truck is running fine and voltage doesn't seem out of line, I'm not sure what you could do.
There are 3 things that will live forever, cockroaches, Keith Richards, and Slant Six Dusters !!!
http://s4.photobucket.com/albums/y128/slantasaurus/
take a look around
 Post subject: ecu
PostPosted: Sun Aug 26, 2007 6:53 pm
I have an NOS Mopar unit on the shelf that has never been installed and it is melting! May just be a bad batch of goo?
. . . there was good sport at his making.
PostPosted: Sun Aug 26, 2007 7:55 pm
Box overheating and melting is a symptom of a coil going bad. :shock:
PostPosted: Mon Aug 27, 2007 9:22 am
It seems to run ok with this unit (NAPA)as it did with the original unit that I took out about a year ago. I may try replacing the coil as a precaution as I know that the coil has never been replaced in the 29 yrs I've owned it. Thanks for the help. Mike
PostPosted: Wed Aug 29, 2007 4:00 am
Mine melted while being in storageon a shelf - some degreaser was spilled on it and afterwards it went bad
 Post subject: melting
PostPosted: Wed Aug 29, 2007 9:02 pm
Back when these first came out ( I was working at a dealership ) we got service bulletins about giving airspace behind the unit. we just put in longer screws and a few 1/4 ' flat washers to help cool the things.Also sand off some paint for a good ground. Some run forever, some don't. just a thought.....
PostPosted: Mon Sep 01, 2014 2:11 pm
I know this is a very old topic, but any updates on this? I just removed one doing this and dont want to ruin a new one. I might try some washers since this is mounted in a 51 plymouth on the fire wall. Coil is new!
51 Plymouth Cambridge with / 6
PostPosted: Mon Sep 01, 2014 2:19 pm
Generally-available modules are virtually all Chinese garbage these days, including the Mopar units. Get a NOS american-made module from Old Car Parts Northwest or, better, do the HEI upgrade.
PostPosted: Mon Sep 01, 2014 3:31 pm
Yea I agree, my wheel cylinders were stamped made in China. See how this lifetime guarantee one from autozone works.
PostPosted: Mon Sep 01, 2014 9:04 pm
Lifetime warranties are a sales gimmick. In practical terms they mean you spend your lifetime returning defective parts again and again and again (until you lose the sales slip). It is worth the extra hassle and price to buy good-quality parts the first time. They generally do not come from the likes of AutoZone.
PostPosted: Tue Sep 02, 2014 9:27 am
Yea well, just bought it as a spare. Same with ballast.
PostPosted: Sat Sep 06, 2014 11:51 am
Update, replacement not melting. Original looked like the original 1980 dodge one, even had mopar stamp on it.
PostPosted: Mon Sep 08, 2014 11:31 am
I have a couple of old ECMs around. In both cases, I have noticed that the epoxy sealant has deteriorated and has begun to slowly ooze out, forming a puddle of sticky, nasty goo. I suspect that age and heat are the culprits. MoPar probably never knew that the sealant would break down over the course of 30 or 40 years.
1961, 1962, 2X 1963's and 1965 Valiant 200. one of the '63's has been shortened by roughly 3 feet. The `65 is a `vert.
Users browsing this forum: Ahrefs [Bot] and 12 guests
