It is currently Sun Oct 11, 2026 12:57 am
 Post subject: Stock exhaust manifold.
PostPosted: Wed Sep 19, 2007 9:33 am
I just bought a super six setup w/ alumin intake.
Are there any improvments that I can make to the stock exhaust manifold, porting ect... I hate to spend money on a header when I have really good stock manifold right here.
Anyway I'm new to the board, this a great place for some great cars
Thank you for your time
,72 Dodge Dart Custom 4dr. 225 1bbl A904
,84 F-150 SB 300 straight six 1bbl, 4sp w/OD
2001 PT Crusier 2.4L non-turbo auto trans
PostPosted: Wed Sep 19, 2007 6:08 pm
Car Model: 63 Dart 81 D150
Gasket matching the intake and exhaust couldn't hurt. I seem to remember seeing on here something about opening the outlet to 2.25 or so. Don't forget to upgrade the rest of the exhaust too.
TopHat
PostPosted: Wed Sep 19, 2007 8:32 pm
If you try to hone or otherwise increase the exhaust manifold outlet to 2.25", you'll bust through it. You can maybe get to 2.125", but don't push it beyond that.
PostPosted: Wed Sep 19, 2007 9:04 pm
the step up in size to an 2.25" exhaust pipe doesn't hurt anything.
just get rid of casting flash, smooth out things and port match (you don't need to gasket match)
Any steps from smaller to larger are ok at the head / manifold interface tooo....
PostPosted: Thu Sep 20, 2007 1:05 pm
Hey Dan, I bored mine out to 2.25. :shock: It's still plenty thick, the only reason I stopped was because of the lack of sealing surface.(didn't want leaks all the time)
I thought they were all that thick, maybe mine is different?????
PostPosted: Thu Sep 20, 2007 2:39 pm
Some are thicker than others. By the time they were offering the aluminum intake, the exhaust manifold collector area had gone from thinnish (early production) to thick (mid-production) to really thin (late "on a diet" production).
And yeah, there's the sealing-surface issue to be worried about, too.
PostPosted: Thu Sep 20, 2007 6:10 pm
Thanks for your input, what about taking out the counter weight and flapper for better flow, or would make it worse?
PostPosted: Thu Sep 20, 2007 6:17 pm
Makes it worse, leave it in. You can choose to disable the spring so it's permanently in the "heat off" position, but I don't advise it.
Users browsing this forum: Bing [Bot], Google [Bot] and 38 guests
