It is currently Thu Apr 23, 2026 5:29 am
 Post subject: Injector angle
PostPosted: Mon Oct 01, 2007 2:01 pm
I am having a hard time getting a clear vision of how my injector rail (or even seperate lines) are going to clear the TPS on my 5.0L Mustang throttle body.
I know that the ideal angle is 45 degrees, but a few have installed them at 90 degrees. What if any issues will I have by using (for example) a 60 degree angle?
Another interesting thought is to install the TB before the turbo inlet. That would allow me to do just about anything including using 2 smaller injectors per cylinder (I am using E85 and big injectors are $$$).
Any thoughts???
Chris'
Autobody
Restoration
Service
PostPosted: Mon Oct 01, 2007 2:07 pm
For those who have any questions about running the TB before the turbo here is the link that put the idea in my head.
http://www.msefi.com/viewtopic.php?t=25 ... urbo+inlet
Chris'
Autobody
Restoration
Service
PostPosted: Mon Oct 01, 2007 2:59 pm
I would probably not be too concerned about fuel injector angles other than the "ideal" 45°. The MPFI versions of the 2.2 & 2.5 engines use a very nonstandard injector angle relative to the intake port, and those engines run well. The injector angle is specifically mentioned as a concern in the SAE paper on those engines, but testing is said to have shown the nonstandard angle didn't adversely affect anything. I don't remember what the angle is, because I can't find the paper at the moment. :-(
PostPosted: Mon Oct 01, 2007 5:22 pm
When you get down to it, the "ideal" injector angle isn't 45 degrees - it's pointed straight at the back of the intake valve, whatever angle that is. However, such an angle is nearly impossible to achieve on a slant six anyway. I wouldn't worry about it too much. My slant six has about a 45 degree angle, but the biggest concern I could see is that you'd have more fuel sticking to the walls.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Tue Oct 02, 2007 3:59 am
You should be able to find some shots of the injector and the addapter plate.
http://slant6racer.mysite.com/?refcd=WSUOWS080630NE03
PostPosted: Tue Oct 02, 2007 8:37 am
Will,
After looking at your pics I see exactly what my concern is. It looks like you can barely slip a piece of paper between your rail and adapter plate.
My bungs should be here by the end of the week. I found some used injectors for mock-up and I will see what I end up with for room.
I am surprised I didn't get any comments on placing the TB before the turbo. I figured I would get some comments :? . The world is flat you know :lol: :lol:
Chris'
Autobody
Restoration
Service
PostPosted: Tue Oct 02, 2007 12:19 pm
Only comment on the TB before the turbo is to make sure you have the right seals in your turbo. The compressor will see vacuum in that set and the wrong seals will draw oil into the intake.
Pretty sure that was noted in your link, so I didn't think it was necessary to mention.
:lol:
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
PostPosted: Tue Oct 02, 2007 1:30 pm
How does a turbo effect the spray pattern? I guess what I am getting at is will forced induction make up for any injector positioning compromises? If the runner is under pressure it will force the fuel into the cylinder when the valve opens anyway, wont it?
Chris'
Autobody
Restoration
Service
PostPosted: Tue Oct 02, 2007 5:07 pm
As long as your fuel pressure regulator is a 1:1 type - 1 more psi of fuel for 1 more psi of boost - the boost will not have a very large effect on the spray. A regulator that's not boost referenced would be trouble.
PostPosted: Tue Oct 02, 2007 8:29 pm
There is a practical limit on injector angle depending on the injector itself - tilt it too close to the manifold and the body may smack it. The injectors I use have a wider body then where the end the fuel exits. Just something to think about - if doing custom work decide on & buy the injectors first if your going to be using radical angles.
You can get around this by building a longer pod, but then the fuel will hit the pod walls, and cause the rail to be even closer to the throttle body.
 Post subject: Injector Angle.
PostPosted: Wed Oct 03, 2007 3:33 am
Hi, I milled and wasted two manifolds to get the best angle and spray pattern.I ended at 35 deg. With about 1 inch between the throttle body and the fuel rail.Hope this helps Max.
PostPosted: Wed Oct 03, 2007 9:45 am
You need to use injectors that are the same as you plan to use for your mock up as there are 3 lengths of injectors and a couple different diameters.
PostPosted: Wed Oct 03, 2007 1:48 pm
Matt, have you been following this thread http://www.msefi.com/viewtopic.php?t=24 ... c&start=20
This idea is very interesting.
EDIT: for some reason my link goes to page 2. So go to the previous page to get up to speed.
Chris'
Autobody
Restoration
Service
