It is currently Wed Dec 24, 2025 10:04 pm
PostPosted: Sun Nov 04, 2007 2:08 pm
Picked up a replacement motor for my pickup and need a little help identifying the year before I work on the rod and main bearings.
Of course it is a Slant Six
Blue in color
Numbers on the Passenger side rearward portion of the block up high are a little fuzzy but they are either:
4F488755 or 4P488755
Two a-fixed tags read 1504: (Yes there is a dot over a dot after the 4) with AAWJ near by.
On the back of the block, up high is a vertical stamp:
PD
Driver side front portion of the block has:
2806830-8 - BH on the driver side of the block farther back
Under the alternator bracket - 4225 R 6 19
5 Freeze plugs with extra ribs on this side of the block.
The rib going back from the water pump mount gets much larger instead of remaining 1/4".
The crank has 52 stamped on one lobe and a B, R or 8 on another. The rod bearing width is 1 inch (not diameter. Width.) Rings on and on if you tap it.
If I understand what I am reading correctly this makes the block a 1968 to 1970 production with a forged crank.
Is there a way to identify a forged crank for certain?
Lead, Follow Or Get The Hell Out Of The Way!
PostPosted: Sun Nov 04, 2007 4:48 pm
4225 R 6 19
1974-model 225 engine built on June 19, 1974.
PostPosted: Sun Nov 04, 2007 5:16 pm
Thanks, once again you are a life saver.
Crank is still forged, right?
PostPosted: Sun Nov 04, 2007 5:22 pm
Yup, cast cranks started in the middle of the 1976 model year.
PostPosted: Sun Nov 04, 2007 5:36 pm
I have a manifold for a two barrel. The distributor is junk. Got any recommendations for fuel and spark combination for a pickup.
It is married to a 727 transmission that I just replaced the clutches and torque converter on.
I want to build for simple maintenance.
Users browsing this forum: Google [Bot] and 16 guests
