It is currently Sun Nov 15, 2026 5:18 am
PostPosted: Tue Nov 06, 2007 5:59 pm
are there any tricks to installing freeze plugs
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Tue Nov 06, 2007 6:46 pm
6 Pack Dart
I have just used a large diameter socket that will fit into the recess of the casting plug , put a little sealant gasket cement not RTV, then tap with a hammer against the socket til the plug is flush.
PostPosted: Wed Nov 07, 2007 3:52 am
I replaced the freeze plugs in my engine in 2006.They're much easier to get at with the manifolds off. I used the gasket shellac and I still ended up with leaks. Very small leaks, I hoped they might stop after a while, but after about 3000 kilometres I still have some that are leaking. The engine shop here locally uses blue loctite. I didn't want to take the manifolds back off to try again, I figured I'd just make them worse.
Blair Furlotte
1979 Dodge Aspen 225 "Super Six" 3-speed
Original owner
Users browsing this forum: Bing [Bot] and 8 guests
