It is currently Thu May 07, 2026 4:54 pm
 Post subject: Vacuum advance
PostPosted: Tue Nov 20, 2007 3:45 pm
Are you supposed to plug the vacuum advance to the manifold vacuum or ported vacuum? I have heard both. Also how should the vacuum pod be adjusted?
PostPosted: Tue Nov 20, 2007 4:06 pm
Ported vacuum -- not manifold. And the pre-'73 vacuum advance units are nonadjustable.
PostPosted: Tue Nov 20, 2007 4:09 pm
I got a electronic distributor from a 74 with a HEI
PostPosted: Tue Nov 20, 2007 4:46 pm
Ah, OK. In that case, don't adjust the vacuum advance unless it gives indications of needing adjustment. A good way to check is to set the engine idle speed to spec, then alternately connect and disconnect the vacuum advance hose while the engine idles and you watch the timing mark with a timing light. if the mark moves as you connect and disconnect the vacuum advance, you need to add a little tension to the spring. Get a 3/32" hex key ("Allen wrench"), insert it into the hose nipple on the vacuum advance, and turn it one full turn clockwise. This should eliminate the vacuum advance at idle, which'll make it a great deal easier to attain a steady and consistent idle (and improve off-idle driveability, too). The one-turn suggestion is just a starting point; use your timing light to verify that there's no longer vacuum advance being applied at idle.
PostPosted: Tue Nov 20, 2007 5:33 pm
ah, thanks. After I do that should I get the Mr. Gasket recurve kit?
PostPosted: Tue Nov 20, 2007 5:40 pm
Dan,
While we're on the subject... Who makes a decent replacement vacuum advance canister? Any idea if the Standard Motor Products cans are adjustable?
PostPosted: Wed Nov 21, 2007 8:51 am
The Mr.Gasket recurve kit is no longer available for MOPAR's.
If you find one or two, by two and let me know, I would like one.
Been looking for one for a year now! :(
Thanks,
PostPosted: Wed Nov 21, 2007 8:55 am
Dan,
On Joshie's question, who makes a 11R adjustable can, I have one but can not find anymore for my other cars.....
Thanks,
PostPosted: Wed Nov 21, 2007 10:03 am
autozone holds them for mopars
PostPosted: Wed Nov 21, 2007 10:07 am
It's possible that all the aftermarket units are being made in one factory and just sold through the various brands, but I don't know for sure one way or the other. AFAIK, all the '73+ units are adjustable, even the aftermarket replacements. Could be wrong on that, too. See this post for available advance cans and specs.
PostPosted: Wed Nov 21, 2007 7:03 pm
Borg-Warner pt.no.V411 is a nice looking peice that is an 11r can that can be adjusted to start coming in as early as 7.5 inchs of vac., or as late as 11.5 inchs of Vac.
If you can find a decent parts store with good parts man,they have hard books that have the cans listed with specs for degrees of advance as well as starting vaccum numbers.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
Users browsing this forum: Bing [Bot], Chuck, Google [Bot] and 3 guests
