It is currently Mon Nov 09, 2026 11:38 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page 1 2 3 Next
What is more important?
Going Fast 67%  67%  [ 34 ]
Looking Good 33%  33%  [ 17 ]
Total votes: 51
 Post subject: 67 Barracuda: twisted 67
PostPosted: Wed Oct 23, 2002 8:40 pm
Car Model: 68 Formula S Barracuda
09/30 - Dutra Duals look cool. 8)
10/28 - Finishing sanding and metal prep of engine compartment.
10/29 - Bolts purchased and assembled engine parts to block. :evil: 1/2 of the bolts I purchased are the wrong length/size.
10/30 - Engine compartment primer completed :lol:
'67 Barracuda drop engine 2nd week JAN 2003, finish restoration MAY 2003.
http://pages.prodigy.net/lasergame/
Bob Brady
Slanted 67 Barracuda
PostPosted: Sat Nov 02, 2002 6:12 pm
11/02 - Began work on wheels and brakes...here are some new pictures of the recently primed engine compartment, and passenger side wheel drum. :shock:
11/04 - Received my new original "Super 225" air cleaner sticker and a "Barracuda" fender script in the mail. :lol:
ImageiImage
http://pages.prodigy.net/lasergame/_wsn/page6.html
Bob Brady
 Post subject: Engine Accessories
PostPosted: Fri Nov 08, 2002 6:31 pm
11/08 - Preparing all "bolt-on" accessories. Everything is sorted and organized and will be ready when engine compartment is painted. The parts shown are a reproduction battery tray, an original restored air cleaner with reproduction decals, a restored cooling fan. Measuring new reproduction stainless steel trans cooler lines. An original "Barracuda" fender script.:roll:
http://pages.prodigy.net/lasergame/_wsn/page7.html
Bob Brady
PostPosted: Tue Dec 10, 2002 8:51 pm
12/09 - Spent 4 hours at the paint store selecting a paint system for my engine compartment. Finally decided to go with a Dupont urethane Chromabase system. Red is the most expensive color.
I went with the orginal color, but PP1, red, for a '67 Barracuda is only sold in lacquer. I had it mixed in the urethane using a cross-referenced formula for the 68 Barracuda. It turns out to be the same color as the '67 :P
12/10 - Began spraying the primer/sealer after breakfast. Started the color coat by lunch, and by dinner I had sprayed 4 clearcoats.
:wink:
http://pages.prodigy.net/lasergame/_wsn/page8.html
Bob Brady
PostPosted: Sun Jan 26, 2003 5:13 pm
JAN 25th..dropped my engine and transmission. The engine and tranny bolted up nicely. With advice from this board I was able to drop without too many difficulties.
After bolting on the transmission, and checking all of the bolt torques, I was ready to "slap" this baby in. Since I spent so much time in the paint job, I was very careful not to scratch the paint. Just one little nic in an area that is covered by the fender so it won't be seen later.
I can't wait to hear it run. It will run for the first time in 15 years. yea!!
:lol: :P
http://pages.prodigy.net/lasergame/_wsn/page9.html
Bob Brady
 Post subject: It Started!!!
PostPosted: Sat Feb 08, 2003 5:23 pm
FEB 8th - Car Started...yea!! It sounds real cool with the Dutra Duals, and no pipes attached.
http://pages.prodigy.net/lasergame/_uimages/car2.bmp
Spent this last week tracking down some ignition problems, and found the points, and condenser needed to be replaced. Heck, the only thing I didn't replace was the ballast resistor. I replaced the voltage regulator twice, I found a ground fault in the wiring, after I chased that problem down, I finally turned the key, and... :arrow:
http://pages.prodigy.net/lasergame/_uimages/car3.bmp
Varooommm!!! The car started right up without any hesitation. It is real loud, and the idle came right down and purred with it's mild cam "loping" very nicely. The last time this car's engine ran was in July 1987.:arrow:
http://pages.prodigy.net/lasergame/_uimages/Car.bmp
Back to sanding the body this next week, so I can get it painted next
month.
:lol: :lol: :D :P
Bob Brady
PostPosted: Thu Nov 17, 2005 1:29 pm
Well it has been a long time since I posted to this forum. Alot has happened, but the biggest thing to happen was our move from Seattle to Northern Virginia.
I started working on my car again. I promised that I would have completed it several years ago...This poor car has been trailered from Seattle to Los Angeles and back, and then we shipped it to Virginia. One of these days I might even be able to drive it more than around the block.
Here are some pictures of my new exhaust. I have finally hooked up to my Dutra Dual set-up. I used the original back half of the original stock manifold, with the casting, that Doug sent me several years ago.
:roll:
Bob Brady
PostPosted: Thu Nov 17, 2005 1:54 pm
ImageImageThe shiny part is my new exhaust.
ImageImageDual tail pipes
Flowmaster 40s.
Bob Brady
PostPosted: Thu Nov 17, 2005 2:56 pm
Bob,
Keep after that project, man! Maybe we'll see you at a Slant 6 race next season? Lots of folks in the VA, PA, MD, NC area...
PostPosted: Tue Nov 22, 2005 1:27 pm
Thanks Lou! I plan to keep on it. I am tuning the engine. Getting the bodywork done and painted by spring 06. :P
PostPosted: Tue Nov 29, 2005 9:48 am
lookin good, and good luck with the burned paint smell i see you painted your exhaust manifolds those are gonna be pretty stinky
:shock:
Cuda Progress :D
The dart as it sits now :(
PostPosted: Wed Sep 26, 2007 4:32 pm
:lol: I believe I said I would have this done by now, but.......can anyone relate to how long these things take. There have been so many changes in our lives, that this project took a backseat for several years, until NOW!!!
Bob Brady
PostPosted: Wed Sep 26, 2007 7:43 pm
Bob
I have a feel for what your saying. Im still amassing parts I start 2 cars this winter :roll:
What am I thinking LOL
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Sep 27, 2007 5:55 am
Bob, you're doing a lot better than me. I took my Duster apart in 2002 for a "quick paint job". It's still a bare shell on a rotisserie with a bazillion dollars of parts laying around. :oops:
PostPosted: Thu Sep 27, 2007 7:58 am
Ha! I thought I was the only smart pants that fell on that stupidity... there's no such thing as a quickie when it comes to a mopar frantic tearing appart the car for a "quick paint job".
Juan Ignacio Caino
