It is currently Tue Dec 30, 2025 11:30 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Wed Mar 26, 2008 9:59 am
so i am also done with the rear i have brake lines to do and get a drive shaft so my question is what car will work for a drive shaft??
If you put an 8 1/4 in place of a 7 1/4 the driveshaft needs to be 1.6" shorter.
http://www.moparts.org/Tech/Archive/axle/5.html
DI listed the correct applications. This list may also be helpful...
http://www.autohobbydigest.com/tables.p ... _slip_yoke
PostPosted: Wed Mar 26, 2008 10:59 am
other problem i ran into today is the e brake don't want to hook up does both side need to be done at the same time
 Post subject: Explain...
PostPosted: Wed Mar 26, 2008 11:09 am
No, if there isn't enough slack to hook the one side up and not the other... you need to go under the passenger side floor pan and look for a little angle bracket held by a j'bolt and nut... douse threads with PB blaster or Liquid wrench, then use a 1/2" flat ratchet (or a normal box end wrench) to loosen and allow some slack... once hooked up, re tighten the nut on the j-bolt, check the e-brake lever for proper operation and stiffness...
PostPosted: Wed Mar 26, 2008 6:36 pm
hey guy i found a guy that is sell one he wants 75 for this is what he said see i want to see what you guys think
I have one that is 49" to 50" center to center that came out of my 73.
I had it bolted to an 8 3/4" rear end but sounds like it might be the
right length.Its has good u joints and a automatic 904 spline on the
transmission end
PostPosted: Thu Mar 27, 2008 9:24 am
i call a drive shop here and the guy said it would cost me 70 to get shorten and balance which i think is a good deal the guy that is sell the drive shaft wants 75 for his, i will got get it shorten today to 49.9 '' which i hope will be the last thing that i have to do to get it back up and run
PostPosted: Thu Mar 27, 2008 9:49 am
Shortened and balanced for $70? Portland area? If so what shop?
PostPosted: Thu Mar 27, 2008 9:52 am
no i am in Eugene the shop name is Drive Line Service of Eugene is 70 good and i do want is shorten to 49.9 in right
PostPosted: Thu Mar 27, 2008 9:59 am
That's a good deal. Yes, that's the length.
Be aware that they will try and talk you into new U-joints and may tell you that the yoke is sprung or some other term to get you to buy more new parts. If you've got the time ask for an appointment so you can wait while they do the job. Call it cynicism through experience.
PostPosted: Thu Mar 27, 2008 10:12 am
will do i can wait until Friday i have nothing to do
PostPosted: Sat Mar 29, 2008 7:52 am
hey guys i got my drive shaft cut and the also did not try to sell me any other parts for it i just have little stuff to do than i am done but the big stuff is done with thanks for all the help i am pretty sure i would not know all the stuff that you guys do so again thanks
PostPosted: Sat Mar 29, 2008 8:19 am
Car Model: 1967 Dodge Dart 270
The last time I had a driveshaft cut and balanced the guy charged me $30. He's been doing driveshafts and rearends since the late 60's. Done some work for me a few times over the last couple years.... I'll have to call and see if the price went up. :shock:
PostPosted: Mon Mar 31, 2008 11:14 am
When I swapped the 8-1/4 in place of the dead 7-1/4 rear in my 90 Dakota, I paid $48 for cut/balance of the drivesvaft.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 14 guests
