It is currently Wed May 13, 2026 4:52 pm
PostPosted: Wed Apr 02, 2008 11:49 am
I recently dropped my steering column in my 73 Dart to do some work. I did it just like the FSM tells you to, and let it rest on the driver seat.
I put it all back together like it came apart but started having some problems. Sometimes the car wouldn't crank when I hit the key. Weird. Then sometimes when I put the car in PARK it would start to roll away on me!
I finally noticed that the gear shift indicator area on the steering column (PRND12) was slightly canted to the right (clockwise) just a bit. So the no start was a neutral safety issue, and the rolling away was a not quite in PARK issue.
I have tried fixing it by loosening everything back up under the column and at the fire wall, but I can't seem to rotate the column back to the left, the little bit that it needs.
Has anyone else ever run into this?
Do I have to shim the cloumn to the left at the bolts where it attaches to the dash?
Thanks for any insight!
Chris E.
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Wed Apr 02, 2008 7:26 pm
You should be able to leave the column bolted up and just adjust the shift linkage. There should be an adjustment on the trans linkage. :D
PostPosted: Thu Apr 03, 2008 6:51 am
Correct me if I am wrong here, but if the part of the steering column which includes the gear shift indicator window is canted, I can't see how adjusting the linkage would correct that.
I would think the column would have to move as a unit.
No?
Thanks,
Chris E.
