It is currently Tue Dec 30, 2025 10:11 pm
 Post subject: Finally Done!
PostPosted: Sun Apr 13, 2008 7:59 am
Well I got my completed motor Firday! After almost 2 years it's 100% complete and installed.I have posted photos of it on
www.flickr.com/photos/emptypockets/
A quick rundown of the build
BH block fully machined,balanced,blue printed,line bored,sonic tested and bored .105 over,milled .50,Ross pistons,all ARP studs and rod bolts,forged crank and nitraded,peend and stress relieved rods,floating pinsMJ windagetray,blue printed high voume oil pump,Rollmaster timing set and balancer,Early Drool tube head,ported(alot) cc'd ,milled 100 ,PSI valve springs,Manley Race Flo 1.72 and 1.50 valves,Beryllium seats,SCE copper head gasket,T/D machine roller rockers,Comp pushrods,Schneider custom Nitrous cam,ported Clifford intake,Hooker Pro Comp split header and a Nitrous Express plate system,Mallory Dual Point dist and CDVI box,I have the 727 Specilities 904 with Coan convertor.Need to make all the final connections and trailer it to the exhaust shop then I can fire it up(my neighbors would not like the noise breaking it in).Then I can start diving it and get it tuned properly before heading to the track.I can hardly wait!I want to thank everyone for the information during this build.I would have never completed this project without this forum.I'll keep you posted when I get it to the track. :D :D :D :D :D :D :D :D :D :D :D :D :D :D
SOOOOO much money spent and I keep gettin' told that I could have had a V-8
PostPosted: Sun Apr 13, 2008 8:04 am
Congratulations! It looks good.
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Sun Apr 13, 2008 8:07 am
Congratulations, I know how good a feeling it is when all that time and money finally falls into place. What sort of compression ratio will all that make?
PostPosted: Sun Apr 13, 2008 8:30 am
Really looks Great. Any plans for a Dyno pull? With and w/o nitro would be cool. Shoot some vidieo if you can.
Thanks
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Apr 13, 2008 9:26 am
Looks great. Let us know how it runs! How much did those pistons run?
PostPosted: Sun Apr 13, 2008 10:24 am
Very nice build, I like what you have done. I would like to ask a few questions if you dont mind anwsering them, if I step on something you dont wish to show just tell me.
The Hooker headers, did you get them from Jegs?
What is the JoB Number on the ROSS pistons?
And what ring pack/set are you using.
Any pics or flow numbers on your head work?
Whats the specs on your cam ( Is the one with split duration & lift)
Jess
PostPosted: Sun Apr 13, 2008 11:00 am
Since the engine has been installed I figure you turned the right side motor mount right side up.
Did you take the leading set of points out of the distributor since you're using an electronic ignition box?
Any particular reason the carb primaries are facing forward?
Why beryllium valve seats?
PostPosted: Sun Apr 13, 2008 6:14 pm
Poser
I'm not worthy! I'm not worthy! :bow:
PostPosted: Sun Apr 13, 2008 6:19 pm
Looks fantastic. Nice job on everything. Like your oilpan work especially. Now the tuning begins...
PostPosted: Mon Apr 14, 2008 3:19 am
Schweeeet! :D
Northern Arizona will not be the same after this! :shock:
PostPosted: Mon Apr 14, 2008 7:51 am
Very cool. Can't wait to hear how she does at the track. Well, now we know why you name yourself - "empty pockets" :D
PostPosted: Mon Apr 14, 2008 8:01 am
That is inspirational!
Well done!
1975 Duster 225, same thing in a van.
Also a bunch of Neons.
 Post subject: answers to questions
PostPosted: Tue Apr 15, 2008 6:46 am
First yes I did flip the right motor mount around.I had it facing down to get in the fixture when I brought it home from the motor shop.The primary faces forwards because it was the easest way to get the throttle linkage to work properly.I got the headers from Jegs.They were supposed to fit my F body but hit the booster so I had to modify the rear tube a little.We used the Beryllium seats because they are harder.Very tough to cut/machine and a little not to healthy to work with(need gloves,eye protection and resprator) but are supposed to be the best.The rings are Total Seal Moly and we ended up with 10.58 compression.Originally we were shooting for 11.0 but when all was said and done we had 10.58.That required another Schneider cam.The specs are roughly108/106 lobe sepration274/230 duration@.50 lift.Remember it was built as a Nitrous motor.The Mallory box can be used with either 1 or 2 sets of points and has a 2 step limiter.The neat thing is it comes with a bypass plug to run just the points,plug and play.I really happy to see the response.It's going to take me a few weeks to get everything buttoned up for the first shake down drive but I'll keep you posted on how it goes.It's been this long now and I just want to get everything as perfect as possible.I'll post some additional photos later this week.Thanks for your encouragement :P :P
PostPosted: Tue Apr 15, 2008 7:36 am
I was serious in my other post about an article in SSRN about your build up. If you want to send me some of the particular information, photos and a little about yourself I will put the article together and send it to Seymour.
Users browsing this forum: Bing [Bot] and 15 guests
