It is currently Wed Dec 31, 2025 10:01 am
 Post subject: Exhaust manifold
PostPosted: Mon Apr 14, 2008 11:12 pm
I was wondering if anybody has experiance with this exhaust manifold?
As you will see, I haven't had much luck this weekend.
http://www.1aauto.com/1A/ExhaustManifol ... 009/568470
They took a picture of port side. Only thing missing is stid to center intake manifold.
Jim
Moon Lite Vans Inc.
PennsylVANia Van Council
PostPosted: Tue Apr 15, 2008 6:17 am
Car Model: 1974 W100; 72 Dart
I had one, it was a nice piece.
sb
PostPosted: Tue Apr 15, 2008 7:51 am
Thanks sb, can you tell me if the center hole is threaded to accept the bolt for manifild?
Is ribbing thicker. I may want to smooth out the exhaust ports. is there enough meat to do so?
Thanks again.
Jim
Jim
Moon Lite Vans Inc.
PostPosted: Tue Apr 15, 2008 8:27 am
I have one of these manifolds on my Dart. It does have the correct threads and a bit more rib than a stock manifold. The bad news is that the casting quality was not up to late '70s Chrysler quality control standards - there was casting flash and huge parting lines everywhere, including places that shouldn't have parting lines. I've heard of a few that had a port blocked with casting flash and had to clean it out. It's a pretty close copy of stock manifold off a later version with the feedback carburetor so wall thicknesses are the same.
One other note: 1A Auto checks to be sure the parts fit the vehicle listed. While normally this would be good customer service, they don't quite realize that this manifold fits a lot more applications than the ones they listed.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Tue Apr 15, 2008 8:43 am
PostPosted: Tue Apr 15, 2008 10:14 am
Ditto what these guys said, but I didn't have any of the problems...just lucky I guess. It came with the triangle washers, heat riser sheet metal and all the intake to exhaust bolts except the center one. I was doing well at last I heard.
sb
Users browsing this forum: No registered users and 16 guests
