It is currently Thu Jul 02, 2026 8:45 am
PostPosted: Fri May 02, 2008 10:48 am
On my '74 225 the front exaust manifold stud is snapped off and the hole in the manifold dose not appear to line up. Can the manifold shift without this stud? And will the exaust holes be partially blocked because of this?
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Fri May 02, 2008 11:44 am
Yes, the manifold can move a lot, even with the stud, and it’s probably that your ports aren’t lined up perfectly. If you remove the rear nut and washer, you’ll probably see that the stud isn’t centered in the hole.
You will have to loosen all of the other bolts and re-align everything. If you do that, it’s a good idea to replace the gasket and maybe all of the studs while you’re at it.
Be careful, though. You can break a few more studs getting the nuts off. I heated mine with a torch after breaking the first one.
You can read all about manifold mounting HERE.
Here are a couple of good threads about gaskets:
http://tinyurl.com/6lqjcs
http://tinyurl.com/68wgku
Danny
Users browsing this forum: Bing [Bot] and 15 guests
