It is currently Thu May 07, 2026 11:37 am
 Post subject: Carb and transmission
PostPosted: Sat May 24, 2008 10:30 am
Is there two different carbs for automatic and standard transmissions? Im looking at buying one and it says its for a standard transmission.
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Sat May 24, 2008 10:46 am
I'll take a guess at this one... The auto carb would have a lever for the kickdown rod/cable.
Chris'
Autobody
Restoration
Service
PostPosted: Sat May 24, 2008 11:55 am
Automatic tranny carburetors usually have dashpots which prevent stall-out by the tranny by keeping the throttle plate from closing suddenly when de-accelerating.
 Post subject: Actually...
PostPosted: Sat May 24, 2008 12:01 pm
Actually the manual tranny carbs usually get the dash pot so it cracks the throttle plates open in the case of a 'high load' and no throttle situation (i.e in gear coasting down a steep hill), which would lean the engine out with high vaccuum and little gas (idle circuit engaged not the mains).
The auto tranny Holley 1945's are similar to the auto tranny carbs as the linkage hooks up in the same location as long as you have all the linkage from your car...
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
