It is currently Thu Dec 25, 2025 9:57 pm
 Post subject: Oversize Valves
PostPosted: Sun May 25, 2008 1:55 pm
Hi Guys
What other chrysler engine valves can be used to upgrde the breating on the slant - I have a set of 318 poly valves but they seem a bit Big
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Sun May 25, 2008 6:15 pm
Ford 240/300ci 6 cylinder valves work, but the exhaust is a bit big. They are 1.78" and 1.56" standard. On my +.030" 225 I had the exhaust valves cut down to 1.45". The stems are smaller, but if you need new guides anyway it doesn't cost any more. You'd need new valve spring retainers and locks, but if you're doing upgrades already the 11/32" retainers and locks don't cost any more than the 3/8" stem items. If you want something a little more 'drop-in' try http://www.engnbldr.com/ He had some stainless 1.70/1.44 (I think) valves with stock stems size. I bought a set as the head I'm doing is going on a stock bore engine any the valves look very good.
PostPosted: Sun May 25, 2008 6:33 pm
Chev 1.72/1.50 valves and springs work.....several folks here including me run them
The chev and 318 valves are longer than stock slant v/vs
I eventually had to go to shorter pushrods with a bigger Erson cam and some decking.
PostPosted: Sun May 25, 2008 11:17 pm
Hi
Wicth chev engine did they come out off?
Regards,
Fanie Gerber
PostPosted: Mon May 26, 2008 7:33 am
It came out of the one that came with my last Sub body......the short block is in the middle of the 350 pile.
1.72/1.50 valves are from heavy duty (3/4 ton pickups) Chev trucks.
Some are 3/8 valve stems.
PostPosted: Wed May 28, 2008 11:29 am
1.72 chevy intakes came in 283 and 307 small blocks. The 1.5 exhausts came in all the first gen small blocks except LT1 and Z28 engines.
I have a set of the enginebuilder valves too. They are very nice, and you can hardly buy any valve for what he sells them for. I just got the rest of my garage unpacked last week and will finally be getting going on using them. Unless you have some special needs, a made to fit valve seems the way to go.
Users browsing this forum: Bing [Bot] and 13 guests
