It is currently Fri Jun 19, 2026 5:46 pm
 Post subject: Cold air intake
PostPosted: Fri Jul 11, 2008 8:15 am
I'm sitting here in Kuwait bored and thinking about my days off projects. I was wondering if anyone is running a cold air intake set up on their car? I found this thread http://www.slantsix.org/forum/viewtopic ... air+intake Now my question is who sells the hose used in this thread? Is it something I can get at my local Napa? Do I need to search the junkyards for it? Thanks in advance Mike
Thanks Mike
PostPosted: Fri Jul 11, 2008 9:59 am
Mike,
Send me your email I will send some pictures of mine. It cost about $10.00 to make with all new parts. It works very well! :D
PostPosted: Fri Jul 11, 2008 10:53 am
Thanks I pmed you. Mike
Thanks Mike
PostPosted: Fri Jul 11, 2008 11:22 am
The pictures and instructions are on there way. Please feel free to share.
PostPosted: Fri Jul 11, 2008 2:22 pm
Hello there mister lowbudget I purchased the tube in that post at Autozone it is made by spectra same with the firewall connector. Both cost less than 15 bucks thanks for the interest.
Image75 dart custom, 225, >10.5-1, hurricane, 500holley, erson cam, 904, 8.8 ford 3.55 or 3.91 aussielocked, 17" steelies, and much more.
PostPosted: Fri Jul 11, 2008 2:30 pm
75customdart,
Did you ever find a machine shop to do your engine machining?
PostPosted: Fri Jul 11, 2008 4:08 pm
I've got to ask.......
How are you going to get 'cold air' in Kuwait?
:twisted:
PostPosted: Fri Jul 11, 2008 5:16 pm
Ted i have been in the process of moving and have not had much time to work on the engine buildup. Thing should soon be back to normal and i will start thebuild soon.
PostPosted: Fri Jul 11, 2008 8:48 pm
"How are you going to get 'cold air' in Kuwait?"
Like I always do with a big air condtioner. Actually I'm only over here to support my Mopar hobby/addiction. It hasn't been so bad this year as the sand storms have been kicking up I've only seen 120 degrees this hitch. Next hitch will be the 130+ hitch. Thanks for all the info
Mike
Thanks Mike
