It is currently Fri May 22, 2026 2:42 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 188 posts ]  Go to page Previous 13 4 5 6 713 Next
PostPosted: Fri Aug 08, 2008 7:35 pm
here is todays progress:
PostPosted: Fri Aug 08, 2008 7:55 pm
As it turns out the only gaskets I have are head, valve cover and fuel pump. Almost all my other leftovers are small block. I have all the bottom end hard parts. Go find a Fel Pro KS2103 and we'll be in business.
PostPosted: Sat Aug 09, 2008 10:59 am
well josh, i have been thinking, not very hard but anyways. i really don't wanna go thru the trouble of borrowing an engine since look what happened to this one. your awesome to offer and thank you very much.
i woudl rather just have help getting this one pulled and on its way to ceej's house. the pistons look good and so does most of the head. i would like to clean the valves but i don't know if i will dammage anything so i am leaving them alone. i have the head painted, it was hard to mask off the rocker arm and stuff but i rigged up carboard and printer paper with masking tape and gave it many good coats of gloss black. it looks awesome! :D
anyways i do have a truck that runs (thanks josh for your help with that!)so it's not like i'm on foot or anything. and we could prolly have that engine together in a weekend @ ceej's.
:arrow: i need to know exactly what parts i need including every gasket. this is my frist engine rebuild and my frist time taking apart a slant six.
and thanks again for any parts donations, either hand them to TH0R since he is @ ceej's a lot or hand them to ceej. that way we can figure out what we are missing. and let's get started! :)
PostPosted: Sat Aug 09, 2008 3:48 pm
ok i have a few questions, i know i have to drain the oil from the engine. but i just put it in 4 days ago along with a new oil filter - a good one two.
so i am assuming that neither is not re-useable. also do i have to pull the fuel pump? it's pretty new so i wanna make sure it stays in good shape.
should i pull the dizzy?
ok i just checked what gaskets i have, i have the following brand new in package:valve cover,2 sets intake/exhaust manifold,water pump,thermostat,egr,2 bbl carb base gasket.
i am wraping the painted parts in tissue paper and boxing them up, also all the screws/bolts are going in little baggies so i don't loose them.
the head is painted and wow i am amazed in teh quality of the finish/paint. it really turned out nice! lets get the block pulled so i can start on the k-member and engine compartment ( stock paint or closest to match with black k-member and steering box )
i'm having fun! if i had a cherry picker and an engien stand i would try to do this all by my self!
PostPosted: Sat Aug 09, 2008 4:51 pm
if you had a bad bearing it not worth the chance of pouring oil and filter with metal in it back into the engine
Neil,keep stroookin' an your baby will be new again.Had to drop a line as I recognize the box your exh mani is sitting on,probably could use the hoist that came in it bout now,right? Oh and your trunk storage pic,man you ought to see my vans(4),all project pieces get stored in um plus other needed junk :oops: Anywho,keep at it and all will be SWEET.You have some awesome guru/teachers down your way,listen an learn,know what I mean? 8) Also I've got a crank with bearings bout 8k miles on it,if you need it we'll talk,you know how my pricing works :) Ta,6shot
PostPosted: Sat Aug 09, 2008 6:06 pm
that's kinda what i was thinking. good to know thanks!
yeah i'm using that box 6shotvanner, and again thanks for the shocks.
i'll get them on the truck after this project is done and get ya those t-shirts made and shipped. i'll be making a lot for thank you gifts for this project! anyways thanks for the replys and i'll just keep going on it till its done!
this is how dirty i was when my friend adam came over to bring me some cold beers:
someday soon i will wear my vintage polyester suits and cruze in my dart all 70's style.
PostPosted: Sun Aug 10, 2008 4:19 pm
today i pulled the fuel pump and dizzy. i finished the paint on the intake manifold and it looks good. kinda weird that i ended up using 3 diff colors of orange on the parts since i am color blind i only noticed it when i had all the parts together and in good light. i had so much greese and oil mixed in with the hair product (dax) in my hair that i had to give my self a haircut to remove it all. even dish soap or bronners soap wouldn't cut it.
i removed the copper sending line to my oil pressure gauge. so all is left is un-bolting the motor mounts and pulling it out. i was thinking of rigging up somthing to the garage and using a come-along wench to get it up and out, but then i realized that i had no way of getting it to my truck or lifted in the bed for transport.
how heavy is a block minus the head?
 Post subject: About 2-300
PostPosted: Sun Aug 10, 2008 4:40 pm
About 2-300 lbs... 70-80 for the crank, and about 135+ for a stripped block with no coolant or oil in it...
Don't for get you also have to unbolt the tranny and support it, as well as pulling your torque convertor bolt or you'll have to 'jack'/bounce the motor a few times to get the convertor off it's shaft...
-D.idiot
PostPosted: Sun Aug 10, 2008 8:00 pm
you can see the 3 diff shades of orange in this picture, but it will still look awesome with a black block & head.
here is my berings and gasket parts quote:
http://www.datapunx.org/autozone%20parts%20quote.pdf
PostPosted: Mon Aug 11, 2008 1:28 pm
All he needs to do is pull 1 last bellhousing bolt, and the motor mounts. I already pulled eveything else.
~THOR~
 Post subject: it's pulled!
PostPosted: Mon Aug 11, 2008 6:03 pm
well a good friend was nice enough to loan me his shop crane! thanks dood u rock :wink: ! it's out! wow my frist engine pull! hopefully the last! i was amazed in how easy it was. i did call for help a few times to be honest :oops: but yeah! next is getting it cleaned up and secure in the truck for transport! i'll keep ya guys posted!
neil
 Post subject: update
PostPosted: Mon Aug 11, 2008 8:24 pm
well by some miracle, i actually had enough to get a complete engine gasket kit. woo ho! i have been scrubbing the engine bay and the stock paint; fenders and firewall looks pretty good. would it be a good idea to shoot some clear coat on it to protect it? tomorrow i am painting the engine mounts and k-member and stuff that i don't know the names for.
PostPosted: Mon Aug 11, 2008 9:12 pm
Midi,
looking good! pulling a motor for the first time is fun..kinda.
Has the cylinder head ever been reconditioned? If not-now might be a good time to do a valve job while you have it tore down. I understand your funds are tight (mine are too) and I don't know what a valve job cost these days...just a thought.
Have fun with your rebuild.
Todd
1968 Valiant V200-a Work in Progress
PostPosted: Mon Aug 11, 2008 10:13 pm
If the engine compartment paint is in good shape just clean it and wax it.
