It is currently Thu May 28, 2026 11:58 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 188 posts ]  Go to page Previous 14 5 6 7 813 Next
PostPosted: Mon Aug 11, 2008 10:34 pm
I know your trigger happy with the paint but may I suggest - get it out of the pulley groove or else it may ruin the belt or at least cause it to slip.
PostPosted: Mon Aug 11, 2008 11:13 pm
I know your trigger happy with the paint.
:D
PostPosted: Tue Aug 12, 2008 5:07 am
if that is original paint or an acrylic 1 step, don`t put clear on it might lift the old paint.
PostPosted: Tue Aug 12, 2008 11:56 am
after josh and terrylittlejohn's advice i am only going to wash and wax the stock paint. here is the k-member and other parts all painted up pretty.
i also took advice from my friend and mentor ceej about using oven cleaner. i think it was in on of his posts. it seems to be cleaning up that nasty oil pan really nice and quick. i used my autozone credit to get my a nice elderbrock air cleaner, so my orange super six one is up for grabs (THOR HAS IT NOW) anyways here is this mornings pictures and progress. i still have SO many questions, i wish i knew what i was doing.
but i am learning a lot about the parts and i find how the engine works extremly cool.
PostPosted: Tue Aug 12, 2008 12:38 pm
i found these 2 thin metal pices in my oil pan.
what r they? and is that what caused my probelm?
PostPosted: Tue Aug 12, 2008 1:16 pm
can you take a piture from another angle and something along side to judge the size.they look like rings but all yours were together?
PostPosted: Tue Aug 12, 2008 1:26 pm
the above photo has been updated
PostPosted: Tue Aug 12, 2008 4:00 pm
it looks like the channel that guides the dipstick to the sump on truck base pans but car pans don`t have them?
PostPosted: Tue Aug 12, 2008 4:06 pm
Midi,
Those metal pieces may be from the #3 main bearing thrust faces. You'll know more when you pull the main caps.
PostPosted: Tue Aug 12, 2008 5:36 pm
more and more it's looking like i might have to buy an engine. :(
we will see when i get the guru's to go thru it.
PostPosted: Tue Aug 12, 2008 5:45 pm
Nah, you just might need the crankshaft that Duster Idiot offered.
PostPosted: Tue Aug 12, 2008 5:55 pm
todays progress:
i'm done untill i can get parts & help. i tryed to order piston rings and 3 part store chains where out of stock so i couldn't even order them. i also am trying to scrounge up cam berings.
PostPosted: Tue Aug 12, 2008 6:22 pm
you shouldn`t need cam bearing unless you are hot tanking the block. if everything is good when you take it apart just high pressure and degrease the block and a hot soapy bath and blow dry, it`s good to go.
PostPosted: Tue Aug 12, 2008 7:10 pm
Nope, no cam bearings, unless you change to D.I.'s cam that he offered, which, is your decision, but keep in mind, we may not have the tools handy to pull those and put new ones in. We really need to take a Micrometer to all that stuff before you order bearings and whatnot, to make sure the ones you buy arent going to be lunched by a non-stock measurement. We also need to Mic the cylinders, to make sure they dont need to be bored/honed. If they do, you are looking at starting a few hundred dollar project here.
~THOR~
PostPosted: Tue Aug 12, 2008 8:18 pm
errrr! i am very frustrated because i have no idea what the hell i am doing, i am getting like at least 5 different awnsers from people. and i really wish i knew more, but i don't. hopefully friday night i can get help figuring out wtf is up.
i'll keep ya guys posted.
neil
