It is currently Fri Nov 13, 2026 11:12 am
PostPosted: Mon Oct 20, 2008 8:19 pm
I have a 71 duster 225 with a stock drivetrain. I recently installed tires size 225/70 14 on the rear axle and now the speedometer is off. I was wondering if anyone knew where I could get a different speedometer gear that would carrect the problem. Thanks
"You know a car is really yours when you've touched every fastener on it." -David Freiburger
PostPosted: Mon Oct 20, 2008 10:53 pm
Use this chart here http://home.earthlink.net/~mopared/speedo.htm to determine what gear tooth count you need. You may still be able to get them from a dealer, at least I did 10 years ago. Don't know of any other sources...anybody else? :?:
PostPosted: Tue Oct 21, 2008 3:48 am
Google speedometer gear, every transmission parts supplier has them.
Yearone's catalog has a nice chart that is easy to pick the proper gear.
http://www.yearone.com/pco/A_0308/full.asp?page=246
