It is currently Tue Nov 10, 2026 12:45 am
 Post subject: Gauge voltage regulator
PostPosted: Mon Feb 10, 2003 9:21 am
The gauge voltage regulator on my '64 Valiant is finally dying. It is built into the fuel gauge. I remember seeing instructions on how to build a replacement using solid state parts, or using the newer separate regulator from a later model (if still available?). Can anyone point me to this information of restate it?
 Post subject: regulator article
PostPosted: Mon Feb 10, 2003 11:27 am
http://www.slantsix.org/articles/instru ... nt_reg.htm
You referring to that one by Chuck?
PostPosted: Mon Feb 10, 2003 1:49 pm
Yes, thanks. The article states that a regulator out of a 67 can be used. Does anyone know how late this external regulator was used? It's as hard to get 67 parts as it is 64.
PostPosted: Mon Feb 10, 2003 2:59 pm
I know that Mopar Action had an article on replacement using a solid-state 5V regulator (Radio Shack for $1) about 2-3 years ago. You might check their website. I will see if I can find my copy too.
PostPosted: Mon Feb 10, 2003 3:09 pm
I know about that article but have now been able to locate it. If you have a copy I'd love to see it.
PostPosted: Mon Feb 10, 2003 5:01 pm
I can tell you how to hook it up if you like... what you are looking for is a 7805, +5v 3 pin regulator. they are cheap, as mentioned can be had for less then a buck. It is about as big as a bottlecap, and has a metal tab with a hole through it , the black square body, and 3 metal legs coming out of it. If you are looking at the front of it where the writing is, and the tab is up, the left pin should go to +12v (input), the middle pin (also same as the tab ontop) is ground, and the right pin is the +5v output that would go to your gauges. make sure all connections are insulated, including the tab. If you'd like I can draw something up so you can see it pictorially.
PostPosted: Mon Feb 10, 2003 6:33 pm
The Mopar Action article Lou mentions is in the Aug 2000 issue. The article title is "Gage Rage", their spelling, not mine, starts on pg 30.
Cecil
PostPosted: Wed Feb 19, 2003 1:35 pm
The regulator you want is a Sorensen IVR3 or equiv. I have had no trouble finding these. I guess I need to make a kit for the electronic version, since my first career was in electronics :!:
Chuck Rivers, Webmaster
Image Image Image Image
