It is currently Mon Nov 09, 2026 10:19 am
 Post subject: Removing oil pan
PostPosted: Mon Feb 17, 2003 2:37 pm
Will I have to lift the engine at all in order to pull the oil pan off a 225 in a Dart Swinger?
PostPosted: Mon Feb 17, 2003 3:27 pm
You will have to lift the engine and get the steering center link out of the way, the best / easy way to do that is to drop the idler arm and turn the wheels full right.
Take a measurment off the oil pick-up to the block's pan rail, so you have a reference to reposition it upon reinstall. (after cleaning)
PostPosted: Mon Feb 17, 2003 4:52 pm
Any way I can support it without needing a hoist (which I don't have)?
For measuring the oil pickup, you mean for reinstalling that, or the pan? I had figured it was seperate from the oil pan itself.
PostPosted: Mon Feb 17, 2003 7:11 pm
You can use a floor jack from underneath, then use blocks to hold the engine up.
For the pick-up tube, you want to get it back to the same height / position in the pan so find a way to do that. Measure or make a template to go by, you don't want to have to take the pan on and off a bunch of times to set the pick-up so it hugs the floor of the oil pan.
PostPosted: Mon Feb 17, 2003 7:49 pm
Oh I getcha. Didn't realize the hight could be changed.
So if I jack up the engine and put say a piece of 4x4 lumber in where the engine mounts go, should I be fine?
