It is currently Tue Nov 10, 2026 4:01 pm
 Post subject: Piston Install friction
PostPosted: Tue Feb 18, 2003 7:08 pm
I was just reading some /6 stuff I had gotten on the net for "off road" modifications. It stated that if you reverse the pistons you will reduce friction. Is this an accurate statement? and is this for race only and not for street? Doc, what do you say?
Thanks,
c-dog
go fast, turn left, don't screw up.
WWW.Mopardropheadcoupe.com
PostPosted: Tue Feb 18, 2003 8:14 pm
I say, do not do this.
You can reduce some friction but it is hard on the rod bearings and piston skirts.
Racers will use pistons with no pin off-set for the best performance.
