It is currently Tue Nov 10, 2026 6:09 am
 Post subject: more fuel pump questions
PostPosted: Wed Mar 05, 2003 11:24 pm
Does anyone know if the mechanical pump runs off the cam or is there a rod inside the motor that's involved? Is there anything special to installing it? It seems like mine is not working correctly (even though it's new) so I will get a pressure gauge to test it. Since my car was sitting for many years, I'm wondering if something inside the motor could be stuck which would not allow the pump to be working properly. Could the cam be worn? How about a picture of inside the engine? Please help !!! :(
PostPosted: Thu Mar 06, 2003 4:34 am
there is a fuel pump eccentric ground onto the cam to drive the pump lever. no pushrods or anything else driving the pump. i've never heard of the eccentric going "round" but i guess it's possible.
-james
PostPosted: Thu Mar 06, 2003 10:14 am
A few things to look at.
It is, in theory, possible to wipe out the fuel pump lobe. I doubt it. Easy enough to check by pulling the fuel pump and taking a peek into the hole.
Another thing to try, pull the distributor cap. Good bet if the fuel pump isn't goin' up-n-down, the distributor won't be goin' round-n-round. If that's the case, you have timing chain problems.
If the lobe looks good and the distributor is moving, I'd check out the fuel lines. Could be a plugged or broken line. Use your lawn mower gas can to either suck gas out of, or pump gas into.
Hope this helps,
Gilly
1960 Dodge Pioneer
"Long Rod" /6, A833 Pistol grip Hurst
8 3/4" w/Suregrip and 3:91's
Still have more parts in boxes than on the car....
Users browsing this forum: Amazon [Bot], Bing [Bot], Dart270, Google [Bot] and 3 guests
