It is currently Sat Dec 27, 2025 8:31 am
 Post subject: Ozzie Slant specs
PostPosted: Tue Dec 16, 2008 7:56 am
You will note the CR increased to 9.2 and the RDP cam - without increase in power?
# High Performance 160 HP "Slant 6" engine:
* Capacity: 225.0 cubic inches (3.7 litres)
* Type: Conventional, watercooled four stroke, reciprocating piston type with 6 cylinders
* Configuration: Front mounted, longitudinal, inlined 30 degrees, "wedge"
* Head: Pushrod and rocker actuated ohv with two valves per cylinder
* Fuel System: Carter two-barrel downdraft type carburettor
* Bore and Stroke: 3.40 x 4.125 inches (86.36 x 104.77 mm)
* Power: 160 bhp (119 kW) at 4400rpm
* Torque: 220 lb-ft (298 Nm) at 2400rpm
* Compression Ratio: 8.4:1
* Valve Timing
o Intake
+ opens: 12° BTC
+ closes: 52° ABC
+ duration: 244°
o Exhaust
+ opens: 50° BBC
+ closes: 14 ° ATC
+ duration: 244°
* Firing Order: 1-5-3-6-2-4
* Radiator Capacity: 18 pints
* Oil Pan
o Without filter: 6.6 pints
o With filter: 8.3 pints
# Pacer High Performance 160 HP "Slant 6" engine:
* Power: >160 bhp (>119 kW) at 4400rpm
* Torque: >220 lb-ft (>298 Nm) at 2400rpm
* Compression Ratio: 9.2:1
* Valve Timing
o Intake
+ opens: 12° BTC
+ closes: 52° ABC
+ duration: 244°
o Exhaust
+ opens: 50° BBC
+ closes: 14 ° ATC
+ duration: 244°
* Oil Pan
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Tue Dec 16, 2008 8:07 am
That's just the ordinary 244°-244°-26°-0.4" camshaft used in North America from '71-'80 and on export 2bbl slants from '67 on. Chrysler Australia for some strange reason never released output figures for the VF Pacer version of the 225. I'm pretty sure they did use the same cam as listed in your rundown (where'd it come from?), but I could dig in the applicable FPC and see if different cams are specified. What cam was used in the RSA ChargerPower engine?
PostPosted: Tue Dec 16, 2008 8:18 am
http://www.uniquecarsandparts.com.au/ca ... aliant.htm - pick yer poison :D
Regards,
Fanie Gerber
PostPosted: Tue Dec 16, 2008 8:25 am
I came accross a charger power engine - in the process of geeting my mits onto it -
BTW have a look at this
http://www.moby302.co.za/chrysler/chrysler_rootes.html
Regards,
Fanie Gerber
PostPosted: Tue Dec 16, 2008 9:00 am
From that first spec sheet, "high lift cam" doesn't mean anything 'cause it's not quantified, and lookit that familiar torque figure of 215 lb·ft...
PostPosted: Tue Dec 16, 2008 10:04 am
Have a cam spec here a came across in a manual - 258/248 .414 lift - intake centerline 109 deg ex 106 - for the 160BHP engine - Dyno sim with this cam and the carb 318 BBD and compression 9.2 - 163BHP on the dot as well as a torque figure of 232lbft - first time for everything
this same sim pitch a stock slant at 125bhp and 205lbft some what down on the advertised figures
Regards,
Fanie Gerber
PostPosted: Tue Dec 16, 2008 11:27 am
Interesting! Sounds like a mismatch somewhere in print...the 160bhp figure seems about right for the 244° cam with the emissions-uncontrolled 2bbl carb setup. So the 258/248 is probably what was used in the ChargerPower 190 engine (and maybe something similar in the Australian Pacer engine?)
PostPosted: Tue Dec 16, 2008 11:30 am
Could be will keep digging
Regards,
Fanie Gerber
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 22 guests
