It is currently Tue Nov 10, 2026 8:48 pm
 Post subject: aaaggghhhhh!!!!!! help
PostPosted: Sun Mar 23, 2003 1:51 pm
wiring help
What should be attached to my coil? Right now i have the wire from the distubuter on the positive side and on the negative side i have the black wire going to a little condensor type thing that connects to the coil mounting plate. I believe i am missing something.
help please
Xsnail
1968 Dodge Dart(might be 67)
1993 MB 500SEL
 Post subject: ok ok i solved that part
PostPosted: Sun Mar 23, 2003 4:28 pm
what type of new dist. should i go with. How much more will going elec. cost?
Brett A. Snell
1947 Ford Biz Coupe (disassembled)
1961 Nash Metropolitian
1968 Dodge Dart
1993 Mercedes Benz 500 SEL
PostPosted: Sun Mar 23, 2003 5:23 pm
You should have a black wire coming from the points in the dist to the neg side on the coil. The positive side of the coil has a blue wire that goes into a harness that leads to one side of the ballast resistor over by the brake master cylinder. Make sure you still have a condenser mouted under the cap next to the points. The condenser thing on the coil mounting bracket is a noise suppessor for the radio.
If you appear to have some wiring problems, get a Haynes #234 repair manual. It has a few wiring diagrams in it along with info to fix most anything on your '67 or '68 Dart. '68s have side marker lights, the VIN# is on the dash and the 6th character in the VIN# will be 7 or 8 for the model year.
There are several ways to convert to an electronic ignition, I prefer using all Mopar parts. Needed is a rebuilt dist $45, wire harness and instruction sheet from Mopar Performance $20 and an orange ECU $35 or chrome ECU $55.
Cecil
PostPosted: Sun Mar 23, 2003 8:11 pm
Thanks i believe i had the wires backwards. Still looking for the other. Did go ahead and get a new dist. They are so cheap why not?!
Brett A. Snell
1968 Dodge Dart
