It is currently Tue Jun 16, 2026 1:14 am
PostPosted: Wed Feb 11, 2009 9:04 am
Perhaps this might seem trivial, tell that to my 63GT. It absoutely dislikes Fram and STP air filters, period. They tend to foul within a month. I have my BBS tuned correctly, not too rich-not too lean, no driveabilty/hot-cold issues, excellent milage return.
Short of going into debt for K&N (which is not available for this set up to my knowledge) What do you folks reccomend and what to avoid.
Dave
PostPosted: Wed Feb 11, 2009 9:35 am
Bobistheoilguy saves the day again:
http://www.bobistheoilguy.com/airfilter/airtest1.htm
He did flow bench testing on all major brands, including K&N.
Short answer is: on a street car run a Napa gold. K&N may help race cars, but is opverhyped for street use. Save your money.
PostPosted: Wed Feb 11, 2009 9:56 am
If you don't want your air filter to foul, perhaps you should remove it completely. But in seriousness, the quickness of your air filter to foul is due to your driving conditions. If they didn't foul, the dirt would end up in your engine.
Have a look at the 3rd page of that report:
Air Filter Filtration Test
PostPosted: Wed Feb 11, 2009 12:25 pm
WIX (=NAPA Gold) or Purolator are good bets. K&N filters are good at only one thing: separating money from your wallet. Off-brands like STP and "value" brands like Fram aren't worth messing with.
PostPosted: Wed Feb 11, 2009 12:47 pm
i likee my K&N...buy it once , clean and reoil put it back on....got them on my harley,my slant and my scion
PostPosted: Wed Feb 11, 2009 12:58 pm
…so it can keep right on doing an unacceptably poor job of cleaning the air going into your engine, eh?
No thanks; I'm keeping my car. See here (holy crap—an OEM AC filter passed only 0.4 grams of dust over the same test the K&N passed 7.0 grams! :shock:) and here ("After only 24 minutes the K&N had accumulated 221gms of dirt but passed 7.0gms. Compared to the AC, the K&N plugged up nearly 3 times faster, passed 18 times more dirt and captured 37% less dirt") and here.
PostPosted: Wed Feb 11, 2009 3:19 pm
Dave
Just out of curiosity, do you live at the end of a long dirt road? I'd agree w/ the Wix / Napa filters by the way, I'm just wondering.
Dietz
for profiles and pictures of my mopars--> http://www.fquick.com/dietz_diggler
PostPosted: Wed Feb 11, 2009 3:23 pm
SSRN National Champion
Wix end of story. Thanks Ron Parker :D
It Aint Over Until I Win
PostPosted: Thu Feb 12, 2009 9:54 am
Since you inquired. I have a Chevron refinery a mile west of work which is also within two miles of the ocean. They have been digging up the Air Force Base for 6 years now, lotsa dust and particles in the air.
Yes I also have a private dirt road 1 1/4 miles of sand and gravel, but this is not my primary residence, i've not had the Dart out that way for several years now.
Dave
PostPosted: Thu Feb 12, 2009 11:01 am
I run a pre-filter over mine which helps extend the life a little. At least it keeps out the bigger chunks. Lots of sand and hay, debris on the free way this year. Since Christmas I collected about a half a cup in the base.
I just order them once a year however, you can wash the pre-filter in the washing machine or by hand and run it through the dryer.
PostPosted: Thu Feb 12, 2009 4:15 pm
So you're in or near El Segundo (as am I), and I don't clog up filters in a month............
Do you have a stand-alone engine breather, or is a hose routed back to the air cleaner?
PostPosted: Fri Feb 13, 2009 8:02 am
Howdy neighbor:
Stand alone, no hoses to the air cleaner on this beast. I had a brainstorm last night :idea: . I've encountered rebuilt carbs in which the gaskets were installed incorrectly restricting vacuum. To date, there's been no obvious performance issues to warrant tear down, if, as I suspect, a rich condition that displays no overt symptoms this could be the culprit ( I find this Dart extremely tollerable to rich conditions). Time to gasket match and invest in a quality filter.
Dave
Users browsing this forum: Ahrefs [Bot] and 1 guest
