It is currently Sat Jun 13, 2026 9:22 am
 Post subject: Engine Weight
PostPosted: Fri Feb 13, 2009 9:18 pm
:?: Roughly what does a Slant Six and a T-Flite weigh???
Starting to smoosh a few numbers so I can figger out a converter and the front to rear %. THANKS!!
If you can't be good, at least be colorful
PostPosted: Fri Feb 13, 2009 9:39 pm
450 lbs for an RG SL6 and another 120 for the 904... "wet".
PostPosted: Sat Feb 14, 2009 8:35 am
Good info!
1969-1/2 Dodge Super Bee A12 (440 Six Pack, 4-spd, Dana 60)
1974 Plymouth Duster 360 (4-spd, 8.75")
1973 Plymouth Duster (225, auto, 8.25")
2001 Dodge Ram 1500 QC 2wd (5.9L, auto, Dana 60)
PostPosted: Sat Feb 14, 2009 9:25 am
Doc, how "dressed" is that?
Manifolds, starter, alternator?
PostPosted: Sat Feb 14, 2009 10:21 am
450 lbs is with everything, including cast iron manifolds.
You can get 25 lbs off that number by using an aluminum intake, t-cover, oil pump housing, etc.
PostPosted: Sat Feb 14, 2009 10:30 am
I figured "wet" included everything out as pulled out of the car. I also assume it was full of oil?
PostPosted: Sat Feb 14, 2009 10:46 am
Yes, "wet" is with the oil and filter.
 Post subject: That Was Easy
PostPosted: Sat Feb 14, 2009 11:22 am
You're the man there Doc!!!...........
And thanks for the reminder about the intake and exhaust manifolds, those things are heavier than a dead terrorist...........
PostPosted: Sat Feb 14, 2009 7:42 pm
A mini starter will shave some weight also.
PostPosted: Sat Feb 14, 2009 8:30 pm
What does a small block weigh? Just wondering what the weight savings there would be with the six?
PostPosted: Sat Feb 14, 2009 9:28 pm
A small block weighs about 50 lbs more than a 225. Aluminum heads on a small block would get the small block down to stock 225 weight.
When I put an iron manifolded 318 in place of the blown up 225 in my road racer the car gained 80 lbs. The differences were the 225 had an aluminum intake and bellhousing while the 318 was all iron. The flywheel was the same size, clutch was the same, same A833, carb, etc.
A small block Edelbrock Performer is 26 lbs less that a 318 iron 2 bbl EGR intake. I took 99 lbs off the nose of my '74 Satellite by doing the manifold swap and removing the under-hood AC parts.
PostPosted: Sun Feb 15, 2009 5:25 am
You'd be losing too much power to make the weight worth saving in my opinion.
Users browsing this forum: Ahrefs [Bot] and 3 guests
