It is currently Tue May 26, 2026 2:46 pm
PostPosted: Tue Feb 17, 2009 12:53 pm
Hello!
Our company has an Aircraft Tow Truck (tug) model JG40PT-9 with an H-225 Slant V-6 Engine. Two bearings are going bad and we intend to either repair or replace this motor. However, I am having difficulty locating any indentification information, such as a stamping or ID plate. Where can I find such info on this motor?
Thanks!
Best Regards,
David Caras
Program Manager, Flight
Global Technical Systems
Airborne & Space Division
Tel: 727-210-1974, ext 207
Fax: 727-210-1975
Cell: 727-744-3399
DCaras@GTSStPete.com
www.gtshq.com
PostPosted: Tue Feb 17, 2009 1:09 pm
The water pump end of the engine, spark plug side, on top of the block (where the head bolts down). On that corner, facing UP is a stamping pad that juts out from the block. On cars/trucks it’s usually under/around the alternator bracket but some have the alternator on the other side.
Danny
PostPosted: Thu Feb 19, 2009 2:39 am
here is a pic of the place.
click
regards,Rod :D
PostPosted: Thu Feb 19, 2009 5:19 am
Wow, thanks for all the help, guys!
Best Regards,
David Caras
Fax: 727-210-1975
Cell: 727-744-3399
www.gtshq.com
PostPosted: Thu Feb 19, 2009 6:48 am
Numbers are:
• 6 K 2258851 2
• 0 3or5 4140
• 091
Numbers in red are best I can see. I had to clean away a bunch of rust & dirt/grease.
This is where I found the numbers:
Best Regards,
David Caras
Fax: 727-210-1975
Cell: 727-744-3399
www.gtshq.com
PostPosted: Thu Feb 19, 2009 7:19 am
H'mmm...numbers are ambiguous as written. Did you leave out any spaces in amongst them? Your images don't display, looks like you forgot to paste in their location. Try again, please? They'll help. Also report what numbers you find cast (not stamped) into the side of the block under the manifolds, and whether there are three or five freeze plugs in that same location.
PostPosted: Thu Feb 19, 2009 10:45 am
can't figure out how to attach a picture.
Castins are:
arrow pointing at 3 o'clock position dot
330-1
6 14 85[/img]
Best Regards,
David Caras
Fax: 727-210-1975
Cell: 727-744-3399
www.gtshq.com
PostPosted: Thu Feb 19, 2009 10:47 am
I found the stampings on the front, sort of behind the fan blade area
Best Regards,
David Caras
Fax: 727-210-1975
Cell: 727-744-3399
www.gtshq.com
PostPosted: Thu Feb 19, 2009 11:39 am
Please follow the instructions located this post.
PostPosted: Thu Feb 19, 2009 12:35 pm
I can send the pictures via email.
dcaras@gtsstpete.com
Best Regards,
David Caras
Fax: 727-210-1975
Cell: 727-744-3399
www.gtshq.com
PostPosted: Thu Feb 19, 2009 1:00 pm
Sending pics via e-mail won't make them visible here on the board.
PostPosted: Thu Feb 19, 2009 2:25 pm
"Program Manager, Flight
Fax: 727-210-1975
Cell: 727-744-3399
www.gtshq.com"
hello,
David, with a title like THAT,I think YOU should be teaching US how to post pictures ! :lol:
no offense intended,I just think it is funny. :lol:
regards Rod :lol: :lol:
PostPosted: Fri Feb 20, 2009 4:58 am
HAHAHA! Guess you're right!
I'll post the pictures tonight.
Best Regards,
David Caras
Fax: 727-210-1975
Cell: 727-744-3399
www.gtshq.com
