It is currently Mon Nov 09, 2026 7:41 pm
PostPosted: Wed Mar 26, 2003 8:19 am
I need to order some oil pump rebuild kits to get the gears and have them heat treated with Doc's next run.
Doc has graciously consented to sourcing a last-minute, group buy of Melling oil pump rebuild kits (which include the gear) for $25 each, (thin rotor kit) this is considerably cheaper than what I've been able to find them for "retail" in my area. Gear hardening fee is $2 each (this batch ONLY), which brings it to $27 per rebuild kit with the gear hardened.
If anybody else would like 1 or more oil pump gears hardened but doesn't have any gears to send and add to the batch, Private Message Doc the following info by 4-1-03:
-your name
-your shipping address
-number, and type (thin or thick rotor) of kits desired
Send payment to:
Doug Dutra
1318 Los Arboles Ave.
Sunnyvale, CA 94087
You will be contacted after the gears are done to inform you what you owe for shipping the gears / kits to you (which will depend on where you live and the weight of your package which will vary according to how many kits you requested).
---Red
 Post subject: group buy
PostPosted: Thu Mar 27, 2003 6:24 pm
<<<bump>>>
---Red
 Post subject: gear buy
PostPosted: Sat Mar 29, 2003 4:55 am
bump
---Red
 Post subject: group pump gear buy
PostPosted: Mon Mar 31, 2003 5:25 am
Final call, fellas...
Tomorrow, 4-1-03 is the deadline.
As noted in Doc's original post:
http://www.slantsix.org/forum/viewtopic.php?t=5240
the cost will jump significantly after this initial batch (as indicated in one of Doc's replies to above thread).
For anybody new to the forum, who may have missed the discussion on this issue, this is what it's all about:
http://www.slantsix.org/articles/oil-pu ... report.htm
Get in on this batch and you'll get a hardened gear PLUS the rest of the rebuild kit for less than what the gear alone will cost you later.
If you think you may want one of these, now's the time.
---Red
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 2 guests
