It is currently Tue Nov 10, 2026 5:30 am
PostPosted: Sat Apr 12, 2003 2:01 pm
were putting it back together now, need torque specs for 67 dart gt 225 /6
we pulled the head, so need specs for everything from there on up
thanks!
PostPosted: Sat Apr 12, 2003 2:11 pm
Here's what I got from a 1970 Mitchell Manual, so this is for a '70 225.
Head-65 ft lbs
Exhaust manifold-10 ft lbs
Intake to exhaust manifold-240 inch lbs
Oil pan-200 inch lbs
Main bearing cap-85 ft lbs
Rear main seal retainer-30 ft lbs
Rod cap-45 ft lbs
Cam sprocket-35 ft lbs
Rocker shaft support bracket-25 ft lbs
Valve cover-40 inch lbs
Oil pump cover-95 inch lbs
Engine front cover-200 inch lbs
Oil pump attaching bolt-200 inch lbs
Water pump-30 ft lbs
Oil filter stud-10 ft lbs
May be a bit of overkill, but oh well.
PostPosted: Sat Apr 12, 2003 9:45 pm
Thank you very much!! We ordered a manual for it but it hasn't come yet!
It's together and running...but needs a little fine tuning yet.
PostPosted: Sat Apr 12, 2003 10:17 pm
Glad to help, eh.
Users browsing this forum: Bing [Bot], curmudgeon, Google [Bot] and 3 guests
