It is currently Tue Nov 10, 2026 7:14 pm
 Post subject: replacing flywheel
PostPosted: Thu Apr 10, 2003 5:52 am
Thought I had a bad starter on my 63 Valiant, but the flywheel teeth worn in two places. I don't suppose I can just remove the transmission to change it? Tried to search for the information with no luck. :roll: :?:
Dan M.
PostPosted: Thu Apr 10, 2003 6:33 am
You can remove the trans and bellhousing (for stick) or the whole trans (for AT) and get the flywheel out. The motor can stay in the car. I've done this dozens of times. If you have an AT, then you'll have to replace the whole torque converter or get a specialized shop to weld on a new tooth ring and rebalance it.
Hope this helps,
 Post subject: ?
PostPosted: Thu Apr 10, 2003 6:24 pm
I ve just cut the welds, flipped the ring around and rewelded it. Of course that only works if only the front part of the teeth are damaged.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
PostPosted: Sun Apr 13, 2003 8:46 am
Bud, the damage is just on the edge. If I flip and weld will I still need to have it rebalanced?
Dan M.
 Post subject: ok
PostPosted: Fri Apr 18, 2003 6:34 pm
Sorry, it took so long to get back, I am in and out here. Shouldn't be a major problem, if the ring is solid like I think it is. I don't know how well those things are balanced to begin with. :?
'66 Cuda 225/4spd
PostPosted: Sat Apr 19, 2003 5:36 am
Thanks Bud, On the bright side, I'll finally get to use my new MIG!
Dan M.
Users browsing this forum: DuckDuckGo [Bot] and 5 guests
