It is currently Fri Jun 19, 2026 9:11 pm
PostPosted: Mon May 04, 2009 6:16 pm
What would be the best way to shorten the e-brake "loop" cable in a 6 Dart. The 8 1/4 rear I just installed had good e-brake cables in the backing plates so I used them and now the cable is too long that connects the two sides. I'd love to swage (spell much?) new balls on one end but don't know how to g about this. Would a simple hardware store wire rope coupling do the job in a reliable/safe manner or should I go about this another way?
Thanks-Howard
65 4-door Dart
70 Chrysler 300
2004 Cummins Ram 3500
1968 Dart GT Convertible-project
Chordomafoundation.org
PostPosted: Mon May 04, 2009 6:25 pm
You don't, not without special tooling at least. Go get the brake cables from your old rear axle and swap them into the 8 1/4.
PostPosted: Mon May 04, 2009 6:28 pm
Cable clamps can be used to make a loop in the cable to shorten it.
PostPosted: Tue May 05, 2009 6:26 am
Waaaaaaay too much work at this point. I need an easier fix. the ols cables were in very poor shape and if I was going to go through the trouble of tearing all the brakes off the 8 1/4 that I just put on and tearing off the old cables I'd still feel like I have lousy cables in which case I would forgo the old ones and replace-w-new IF I could find them which is doubtful.
I'm thinking I'll come across something that will allow me to safely shorten the one loop that bridges the rear wheels.
Thanks-Howard
65 4-door Dart
70 Chrysler 300
PostPosted: Tue May 05, 2009 6:49 am
Howard
Like Sandy says the cable clamps work great. I used 2. That was 15 years ago, the cable finely rusted threw due to Ohio's salted roads.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed May 06, 2009 4:26 am
Thanks-Howard
Rock auto parts. Raybestos part number BC92205 $15.95 ea.
http://www.rockauto.com/catalog/x,carco ... -autoparts
Also available at most part stores. Just because it is for an old car, doesn't mean the part is made of unobtainium
PostPosted: Sat May 09, 2009 12:11 am
I agree case in point - My 78 CL Regal SE lost its rear wheel cylinders - shopped around on the net very expensive $40 each excluding shipping.... so I decide to have them relined new pistoms ,mmad - wnt to the Brake guys the guy gave it one look turned around and too two of the shelf for ...$40 total - the correct PBR OE part - now how is this possible?.. FORD still use these with their imperial threads on the 2008 model Ford Bantam LDV
Was able to source ALL the brake hardware this way
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
