It is currently Wed Nov 11, 2026 10:09 am
PostPosted: Thu Apr 24, 2003 7:04 pm
I'm interested, if anyone has anykind of knowledge, what kind of air / fuel ratio you have at idle and at cruise. and also how your engine acts with those numbers.
Joug
Sorry, my english is not very good
PostPosted: Thu Apr 24, 2003 8:37 pm
Joug,
I recently have been monitoring my high performance Slant with an O2 sensor. I have a long duration cam, so my idle is smoothest and take-off is easiest with a rich mixture - like 0.8-0.95V on the O2 sensor. The mileage on the hwy is best with a lean mix - about 0.2V on the sensor. I have been tuning WOT (wide open throttle) at around 0.85-1V.
Hope this helps,
PostPosted: Fri Apr 25, 2003 9:42 am
Thans Lou
That is somenthing i'm hopeing. But if I adjust carb richer, the air fuel ratio starts to wander very much. From 0.05V- 0.9V. I really mean 0.05 v. My cruise mixture is now Steady , but it is steady only when it is too lean ( now about 0.07V). Of course, with carb, it's allways wandering little , but that is too much. But when accelerating it is ok ( 0.8-0.95V). IDle is quite similar than yours Lou.
I still would like to know, how much that very much advanced timing chain does for that mixture and MPG's. It's stock engine. I explained that before in other topic, But here again:
I changed timing chain and sprockets and checked cam degree. Centerlines are I/E 101/117 degrees. (federal mogul timing set) I also found at Slantsix.com that somebody else has degreed his similar set and he also found same centerline. (half tooth off). Where that stock cam should be set? 106/112 ???
Joug
Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
