It is currently Tue May 26, 2026 4:46 am
 Post subject: slant 6 engine size I.D.
PostPosted: Sun May 24, 2009 10:16 am
How can one determine whether you have a 170 cu inch or a 225 cu inch? Is it encoded in the engine block number? If so, where is that located? Thanks,
John in Colorado
 Post subject: Engine numbers
PostPosted: Sun May 24, 2009 10:40 am
Yes, it is stamped on the block above the coil. There is a ledge on the block deck that has a string of numbers. Clean up that area between the block and head and tell us what you find.
Take a look at this table from the articles section on the front page of this website
http://www.slantsix.org/articles/parts-matrix/jpg.htm
SL6 Dan also has the secret decoder ring.
PostPosted: Sun May 24, 2009 5:48 pm
Ted, thanks for the quick reply. It's a 170, which after reading up on other comments on the 170, I'm kinda psyched about. I just ordered a clutch kit and have the replacement 3-speed trans ready. I thought it odd there were no other engine serial numbers near the "170". Is that odd?
John in Colorado
Users browsing this forum: Ahrefs [Bot] and 6 guests
