It is currently Fri May 15, 2026 2:06 am
PostPosted: Tue Jun 02, 2009 11:01 pm
I have 9 in drums on the front of my Dart. The fittings that come off the hard lines and meet the rubber hose are stripped.So I am going to have to cut the line, install a new fitting,and then flare it. Anyone know where I can buy the fittings?What size/part number?
1967 Dart 9x2" drums on all four.
I blew a front hose,and cant get it off.Need help as soon as possible,its my only car.
Thanks :D
PostPosted: Wed Jun 03, 2009 1:09 am
If it’s a regular brake line fitting, you can get them at most real parts stores. They also have brake lines, flared and assembled with the fittings, in different lengths so you can just match one up and bend it to fit.
Danny
PostPosted: Wed Jun 03, 2009 5:26 am
That is correct-- you can even go to auto zone-- get the straight tubing with the correct threads-- use a socket or purchase the tubing bender.
I used the old line for a pattern & made them work for a 62 valiant.
Or places like inline tube & such will have kits to replace your lines.
Take care not to strip the threads of the junction block. The new lines should be a little longer than the original-- just adjust the bends to allow for this.
Lawrence
PostPosted: Wed Jun 03, 2009 2:23 pm
Thanks,you guys are awesome!
