It is currently Sat May 16, 2026 6:29 am
PostPosted: Fri Jun 05, 2009 5:16 pm
I'm upgrading to the 11.75" BBP Disc setup on my 71 duster. It sees 350+ miles a week in daily commuter fashion.
What else should I do to it while its apart? I will be adding a sway bar at a minimum. Haven't figured out what brand yet. I have a set of LCA with stock swaybar tabs on it, may use those. Is it worth adding the stiffening plates to the bottom?
What about the solid strut rod mounts? Worth it for a street car, or will they wear out too quickly? Maybe compromise with a middle of the road solution and use poly bushings here?
Already has 0.890 (or was it 0.920"?) bars and KYB shocks. Are the Edelbrock IAS or other shocks worth the money or should I put it towards other upgrades?
I don't know if there are any other new doo-dads that came out for these front ends, haven't payed attention much to this area of the car in some time. Anything else I should put some thought into?
Has anything changed brand wise interms of quality for general things like balljoints, or is it still hit and miss?
PostPosted: Fri Jun 05, 2009 6:51 pm
How 'bout a Reinforced K-frame: http://www.firmfeel.com/reinfkfram_a.htm
Or a sway bar kit: http://www.firmfeel.com/swaybars_a.htm
Or Upper Control Arm Eccentric Bolt: http://www.reillymotorsports.com/store/ ... 275&page=1
Or Tubular Upper Control Arms: http://www.firmfeel.com/tubuca_a.htm
Or Adjustable Upper Control Arms: http://www.reillymotorsports.com/store/home.php?cat=265
Or Reinforced Lower Control Arms: http://www.firmfeel.com/reinlca_a.htm
Or Greasable Lower Control Arm Pins: http://www.firmfeel.com/lcapins_a.htm
Or Seamless Tubing Tie Rod Kits: http://www.firmfeel.com/tierods_a.htm
Or Adjustable Strut Rods: http://www.firmfeel.com/adjstrut.htm
and: http://www.reillymotorsports.com/store/home.php?cat=266
Or Fast Ratio Pitman Arms: http://www.firmfeel.com/fastrati.htm
Or Power Steering Box and Pump: http://www.firmfeel.com/powerst_abe.htm
Or Fast ratio or stock Manual Steering Box: http://www.firmfeel.com/manualst.htm
Just the cool factor alone is worth the price!
--Walt Jackson
Last edited by Walter Lee Jackson on Fri Jun 05, 2009 6:58 pm, edited 1 time in total.
PostPosted: Fri Jun 05, 2009 6:55 pm
Clean and paint the parts.............
PostPosted: Fri Jun 05, 2009 7:33 pm
Yeppers on the paint, gathering the supplies for that as well.
Firmfeel stuff is spiffy. I think my k-frame is fine the way it is, maybe next time I have the motor out I can beef it up.
I'm using the stock 73-76 UCA with the offset bushings. I already have their 20:1 manual box. Their sway bar is definitely a possibility.
I was thinking of 11/16" tie rod setup. Are seemless tubing ones that superiour? Wonder if anyone else makes them.
I was referring to the RMS strut rods in my original posts. I'll have to contact Bill and see what he says about putting them on the street.
PostPosted: Fri Jun 05, 2009 7:52 pm
Use rubber strut rod bushings on the street. Unless you are road racing you don't need anything stiffer. I used heim jointed strut rods on my race car, but it was a gutted and caged closed course racer.
.920" torsion bars are a good start. Sway bar would be a must. I think the big tie-rod assemblies are over hyped.
I need to get on the ball and put my 20:1 parts in my steering box. 24:1 sucks when carving corners. I run 1.04" torsion bars and QA1 shocks.
PostPosted: Sat Jun 06, 2009 10:50 am
I don't know if they help any but I made some for my LCA's and put them on. It's easier while you have them out. Make sure the adjuster access holes allow plenty of room for a socket. The plates do add a little unsprung weight.
PostPosted: Sun Jun 07, 2009 8:14 am
Yeah, made some for my swinger out of 3/16" mild steel. I'm sure they help considering the design of the originals. I think they cost me a few dollars and an afternoon. If you have a welder and a decent plasma cutter they're a snap to fab.
-James
PostPosted: Wed Jun 17, 2009 2:47 pm
Sway Bar!!! not that you need the front end torn apart to put one on.
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Wed Jun 17, 2009 8:48 pm
Yep, FirmFeel bar should be here next week. Wheels should be here tomorrow... lets see only thing left are the balljoints/bushings/etc.
PostPosted: Thu Jun 18, 2009 3:20 pm
sweet! you also might want to throw in some stiffer Torsion bars. that you do need the front end torn apart for. good shocks are a must too
PostPosted: Thu Jun 18, 2009 3:22 pm
I have KYB's on there now. I thought about the Edelbrock IAS but for the price I'd rather put it into something else.
Torsion bars are... I forget what I put in, 0.890" or 0.920" were from last front end upgrade.
PostPosted: Fri Jun 19, 2009 8:02 am
On the shock issue, are Bilsteins or Konis available that will fit in an A-body? My Cuda that was redone in the 80's has Koni shocks, but I don't see them for Mopars anymore.
PostPosted: Fri Jun 19, 2009 11:09 am
I had Kyb's and went to Eddies. I noticed a big difference, but not sure if it was worth it for the price. I'd try the QA1's. I use the solid heavy duty strut rods from espo and rubber bushings. I've had no problems with em. not sure if you really need adjustable. everything else is poly bushings. handles awesome but its squeeky.
