It is currently Thu May 21, 2026 1:09 pm
 Post subject: 198 Rod Conversion?
PostPosted: Thu May 01, 2003 9:09 pm
Site Admin
:? I've priced 2.2 Turbo pistons, but am having trouble finding 198 Rods. What sources are out there for new?
With the Long Rod conversion, if the head is shaved, will the KB pistons be able to absorb the valve relief?
This will run on 92 Octane Pump gas. Should I forgo milling the head? Just ordered a comp cams 64-241-4 "K" Kit. (4 weeks wait...)
My piston source quoted a price of ~$230 for a set of 6. Sound about right?
Thanks!
CJ
Valiant
PostPosted: Fri May 02, 2003 9:46 am
The 198 rods are the hardest thing to find for this combo.
198's were only offered for 5 years as a "base engine" (1970-74)
There are no known supplies for NOS / new factory forgings, there are some aftermarket 7 inch rods offered through the Cox Boys. ($$$)
I think there are some possible sources for used 198 con rods listed in the parts database.
Your quoted piston price is "spot-on" but get the 198 rods "in hand" before ordering pistons.
 Post subject: 198 Rods
PostPosted: Fri May 02, 2003 11:07 am
Site Admin
Copy that.
I'll see if one of our local /6 collectors has a 198 or some substantial chunks of one.
Thanks for the Reply! :)
CJ
 Post subject: Pistons
PostPosted: Fri May 02, 2003 3:18 pm
Are these pistons the forged units??
Rick
PostPosted: Fri May 02, 2003 8:56 pm
At $230 they sound like Hyperteutectics. They will bite you about another $120 for rings. :shock:
In all honesty, I have a 198/2.2 motor and I am not really convinced that the extra hassle of finding the rods and pistons is worth it. If I was building a high winder and wanted the lightest possible pistons, then yes it would. For an average street motor, I don't really think so. :?: (I am building another one for my race car though. :roll: )
PostPosted: Fri May 02, 2003 9:55 pm
Site Admin
These Pistons are the KB268's.
So far I've been striking out on the rods. :shock:
As this is a street engine, perhaps I'll go in another direction.
As is, I'll need to cut the Head down to make use of the cam. I'm wondering if the GM 3.8 Throttle Body set-up is going to flow enough air...
Fortunately, I'm finding lots of options for the intake and exhaust. I've got two complete exhaust manifolds for a Dual if needed.
(And the big cam is on it's way)
Nothing like getting started a bit early.... :oops:
I'll have my favorite machine shop rework the heads when the Cam gets here. Any thoughts on how much to take off for 92 pump gas?
What is the thickness of the Felpro Head Gasket?
CJ
 Post subject: Some info...
PostPosted: Fri May 02, 2003 10:23 pm
'Squash' height of the fel-pro composite gasket is .039-.043....
GM TB's usually flow 670 cfm...
good luck on the build up...
PostPosted: Sat May 03, 2003 10:27 am
You should be able to safely run between 9.5:1 to 10:1. I milled the head on my stock slant to give about 9.5:1 with no problems.
Mitch
PostPosted: Sun May 04, 2003 4:10 am
There is currently a set of 198 rods on Ebay:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33623
Mitch
PostPosted: Sun May 04, 2003 5:34 am
I do want to amend my statements from the other night here now that I'm awake. While I am not too sure that the 198/2.2 combo makes any more power than a stock piston/rod deal, it does seem to make the engine very resistant to detonation. Mine is right at 11-1 and it runs on pump gas. :shock:
PostPosted: Sun May 04, 2003 9:14 am
Site Admin
Dontcha Love Ebay. Gonna have to bid some more I guess.
I thought I saw an outfit selling 198 Rods for ~$35 a piece somewhere.
Any leads on that? I'll go trundling about the articles again. Maybe I'll find something.
At 670CFM I doubt I'll have any breathing issues. I'd better do something substantial with my exhaust though!
Thanks for all the leads and information!
CJ
PostPosted: Sun May 04, 2003 5:50 pm
http://www.moparts.org/ubb/Forum14/HTML/000165.html
the ones at moparts are only 80 bucks shipped
73 swinger holley 5200, 2 1/4" exhaust .030 over new pistons , cam, .010 under crank. stock everything else. 1/4 mile about a week. 0-60 around 15 sec.
PostPosted: Sun May 04, 2003 7:40 pm
Ah yes, my old buddy Mark "Slant 6's suck" Nixon. :lol: :shock:
PostPosted: Sun May 04, 2003 9:08 pm
Site Admin
Thanks!
Just sent a message to try to get that set.
CJ
PostPosted: Mon May 05, 2003 8:11 am
Site Admin
Nope. :shock: Already sold.
Keep me in mind if you see a set. I'm still lookin'
I'll get back up on Ebay and see where that set is at.
CJ
Users browsing this forum: Bing [Bot] and 10 guests
