It is currently Sat Nov 14, 2026 10:50 am
 Post subject: Oil Pump to Block gasket
PostPosted: Sun May 04, 2003 2:46 pm
I'm having trouble getting an oil pump gasket . . . NAPA can bring one in from elsewhere but my question is this . . . Does one have to use a gasket here or have people been using gasket maker sealants here?
Cheers!
Al T
PostPosted: Sun May 04, 2003 3:40 pm
replaced the block in my 74 and had to buy a sheet of gasket and make one. It wasn't hard to make, just a bit time consuming. I'm not the type to use RTV on anything having to do with oil flow, but that's just me...
.02...
PostPosted: Sun May 04, 2003 7:03 pm
Got mine from Cox Bros for a couple $.
65' Dart. A work in progress..
______________________
Joe
PostPosted: Sun May 04, 2003 7:13 pm
Air leaks with an external oil pump are a very bad thing. My neighbor found out the hard way on his Isuzu Trooper. Make the oil foam. Make sure you have a good seal. Back in the "old" days we'd make cylinder base gaskets for two strokes out of phone book covers...ah yes the "good ole days" :?
go fast, turn left, don't screw up.
WWW.Mopardropheadcoupe.com
PostPosted: Sun May 04, 2003 8:08 pm
I just put mine back on with a very thin layer of Mopar gray silicone. So far, so good. :shock:
 Post subject: NAPA it is then
PostPosted: Sun May 04, 2003 9:54 pm
I picked up the Felpro gasket set from Cox which worked out great for me . . . just discovered that the oil pump gasket wasn't included. There wasn't a chance of me reusing the old one. It was extremely baked on and took a ton of elbow grease to remove it very small chunks.
I guess NAPA is it then. I just didn't want to wait for a $2 gasket.
Cheers!
Al T
PostPosted: Mon May 05, 2003 7:23 am
Al,
I have a stack of these and I could mail you one if you email me your address.
PostPosted: Mon May 05, 2003 9:11 am
I just took a look at my FelPro gasket sets. Mine came with 2 oil pump gaskets. 1 for the 5 bolt pump, and 1 for the 6 bolt pump.
PostPosted: Mon May 05, 2003 7:58 pm
Lou thanks for the offer but I should have a couple by tomorrow am unless I got the wrong ones. My pump is a six bolt . . . which years had 5 bolt?
Cheers!
Al T
PostPosted: Mon May 05, 2003 10:22 pm
I think it was just the aftermarket "replacement" pumps that had the "5-hole" deal. These are the 7/8 rotor thickness pumps.
I'm not sure if any 5-hole pumps ever came from the factory.
PostPosted: Tue May 06, 2003 6:24 pm
I went to pick up my gasket today (ended up ordering it thru a Chrysler dealer) and it was a 5 hole. When ordering over the phone, I'd told the guy slant six and he said my book only goes back to '82. I said no problem, trucks had slants in '82 and he said, then I'll have a couple in tomorrow.
In person today, I had them hall out the old 60 parts book and when they checked with the 6 hole gasket part number [2121 404], they had 10 in stock at their western Canada warehouse.
Cheers!
Al T
PostPosted: Sat May 10, 2003 7:49 pm
Doc-
My '87 truck block came factory with a 5-hole pump. The block only has casting for five holes, the original pump had casting for 6 but only five holes drilled. Im guessing only very late blocks came like this.
-Aaron
PostPosted: Sat May 10, 2003 8:11 pm
See my other post, "oil pump info". Posted it before I read this.
Users browsing this forum: Amazon [Bot], Google [Bot] and 10 guests
