It is currently Tue Dec 30, 2025 4:48 pm
Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3 Next
 Post subject: ET chopper
PostPosted: Sat Aug 08, 2009 11:33 pm
Well Mark, what's that converter flash at? Continental makes a pretty good unit and they're usually pretty efficient as well so you'll get nothing there. The 2.74 gear set MIGHT get you something in the lights but will chop 60' times but it sounds like the car's making good forward progress with both times. Is it in it's very best state of tune right now..jetting/timing/lash/etc? Have you played with the shift loops much? Sometimes, depending on the car and engine combination, that can make as .1+ difference. It's always the little things...wb
PostPosted: Sun Aug 09, 2009 8:18 am
Looking back at everybody's ideas how about this plan.
1. Cool high air density day
2. Wide band AFR Sensor with a gauge, you don't need a computer to just read the ARF but you do need a fitting in the collector. This could give you valuable information to adjust the carb. Sometimes there are flat spots that can be cured variious ways. Mount the gauge so you can see it without being distracted.
3. Put in the 5.13 gear if you just want to do 1/8 mile. That will give you the same breakaway as a 2.74 low with a 4.56 with out the big RPM drops when you shift.
4. Put on an electric water pump drive, you might as well take the alternator off the car, charge up the battery and get ready to make your bonzi run.
This might not get you into the 7s but should bring you closer. I will send you a PM to put you in touch with Bernie Kuschel, he ran a 13.22 with his Lancer street car with an engine quite similar to what you have and much more weight.
PostPosted: Sun Aug 09, 2009 8:44 am
Have a AFR gauge in the car,Its a Wego 2,cant really watch it tru a run,,too busy.just have to have someone plug in my lap top to read out at the end of the run,Havent played with jetting,have tried a few different valve lashes.Where do you get elec water pump for a slant?I do run my alt,pump belt very loose,am running elec fan,Mark
PostPosted: Sun Aug 09, 2009 10:04 am
Get one of the moroso universal electric water pump units, and run it on a switch. I think this is the same setup Ron Parker uses.
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Sun Aug 09, 2009 4:21 pm
Just went and gutted a old used water pump,got the Summit catalog in hand,planning my attack on this project,wonder what the stock gpm flow is for a stock pump,Thinking i can block off the front and just put a pump in line of the lower radiator hose???Mark
PostPosted: Sun Aug 09, 2009 5:38 pm
Although you can rig up a small electric water pump to work, it takes a lot of special fittings to use it with a stock type radiator. What most people do is drive the stock water pump with a small electric motor and a gilmer belt like the Moroso kit that was mentioned. The brackets that come with it are usually for a chevy but you can adapt them quite easily, you might have to fabricate a piece or two. You can actually get by driving a limited amount on the street with such a set up, otherwise you can remove the stock water pump pulley when you get to the track and substitute the plactic gilmer pulley that comes with the kit. This is hard to do on an early A body with a stock radiator due to the limited clearance between the radiator and the pulley, if I ever want to do this on my car I have to drain the radiator an pull it up to get at the pulley, hopefully your aluminum radiator has more clearance. After you take off the water pump pulley you need a different length fan belt to drive the alternator, that's why I suggested taking it off to save 12# or so.
PostPosted: Sun Aug 09, 2009 6:09 pm
will pull alt at the track,think I am going to get the Summit SUM-314-440 elec pump and cut the front off my gutted pump,weld a plate and bolt this on.The Moroso elec drive is tempting,,,too easy and cheap,I need more of a challenge and try to build a better mouse trap,just the way I am,Thank You all for your guidence,Keep em comming,Mark Oh,the 5.13 gears have been ordered,will put them in my 3.91 extra rear end
PostPosted: Sun Aug 09, 2009 6:22 pm
You might also consider the Davies-Craig electric water pump here
-Moose
1966 Clark Cortez, Industrial /6
PostPosted: Sun Aug 09, 2009 6:30 pm
Very cool and would save me work,but is out of my price range right now,Stewart components also has one but its over $400 also,I would like to do this for under $200,THANK YOU for pointing it out,Mark
PostPosted: Sun Aug 09, 2009 9:38 pm
Could try one of these...
http://www.boatfix.com/shop4/store/view ... oduct=9480
PostPosted: Mon Aug 10, 2009 10:33 am
As for the alturnator, I have a field cut-off switch so I can turn-off the magnet load inside the unit, when making a pass. I switch it back on and re-charge as I come back on the return road.
PostPosted: Mon Aug 10, 2009 8:56 pm
I fought my car looking for any improvment for a year. I tried 3:91 and 5:13 gears, taller & shorter tires, 350 holley on an adapter, different length header collectors, etc. It ran within a few hundredths no mater what. I ran a five blade fan from a V/8 Aspen. When I removed the fan, installed an electric fan and a Moroso water pump drive (some modification required) my car dropped 5 tenths and gained 3mph. These times are for the 1/4 mile. When I poured in C12 race fuel it was 1.5 tenths quicker yet. I don't know what it will do for your car but a couple of hundred dollars should cover it.
Necessary Evil Racing
PostPosted: Mon Aug 10, 2009 9:13 pm
Bought a CSI electric pump today,spent several hours mateing it to a stock houseing,CLOSE, but I want the impeller further in,Will re-do,probably anouther 4 hours butt will have it how I THINK it will work.Pics to follow,Mark
PostPosted: Mon Aug 10, 2009 9:19 pm
I will be in Sacramento race sept 13 with a elec water pump provideing i dont hurt the motor between now and then,Mark
PostPosted: Mon Aug 10, 2009 10:58 pm
My cutout is a micro switch on the carb that opens the field circuit, at wide open throttle. All automatic, don't even have to think about it.
