It is currently Sat Aug 15, 2026 2:35 pm
 Post subject: Timeing issues
PostPosted: Tue Aug 18, 2009 12:21 pm
I recently went and put the electronic distibutor in my slant six, Mopar factory style but The only way it start's and runs good is with the distibutor rolled back counter clockwise all the way, Start's and runs good there but it seems I'm not getting as good milage, and it's running a litle warmer than before. My question is did I get the distibutor one tooth out of time if I did what do I need to do to fix it :?
PostPosted: Tue Aug 18, 2009 12:50 pm
Did you check the timing with a timing light?
 Post subject: dist
PostPosted: Thu Aug 20, 2009 2:50 pm
if you look under the distributor you will see the hold down piece can be adjusted too. It can be a pain. I like to get it snug but not tight, rotate the dist to where there is good travel on the outer hold down slot, pull it then tighten the hold down to the dist.
good luck
madam im adam
PostPosted: Thu Aug 20, 2009 5:26 pm
I got to tinkering with it yesterday, I put my timeing light on it and got it to fireing and idleing at 8 or 9 degrees after pull the gas and it's going full advance and it's running pretty smooth so I think I may leave it alone right now
PostPosted: Thu Aug 20, 2009 6:53 pm
make or take the time to get it runnig the best you can..it takes the worries away and makes driving soooo much better all around....
besides she likes your hands all over her :D
Its so nice out side, I think I'll go lay under my car..
